Old 12-10-2008, 10:54 PM   #1
jeep93zj
jeep93zj's Avatar
xj problems
i got a 89 xj and i was wheelin the other night and my heater my radio and my cig lighter all quit workin at once any ideas would help thanks
89 xj 5" rustys
93 zj 7" rockcrawler springs with rustys long arms
jeep93zj is offline   Reply With Quote
Old 12-11-2008, 07:28 AM   #2
tinbeater
tinbeater's Avatar
Check the fuse?
Old 12-11-2008, 07:49 AM   #3
Check the fuse?
x2
Old 12-11-2008, 08:05 AM   #4
I think those are all on the same fuse, so possibly your radio or heater blew it. Should be under the dash on the drivers side.
Old 12-11-2008, 08:15 AM   #5
If it is the fuse just put a larger one in its place and make sure to keep a fire extinguisher handy!
Old 12-11-2008, 03:08 PM   #6
jeep93zj
jeep93zj's Avatar
all the fuses are good thats the problem
89 xj 5" rustys
Old 12-11-2008, 03:31 PM   #7
Is power going through the fuses? Relays under the hood and fuses under the hood good?
Old 12-11-2008, 04:28 PM   #8
jeep93zj
jeep93zj's Avatar
no power is geting to the three fuses and the relays are good
89 xj 5" rustys
Old 12-12-2008, 12:25 PM   #9
tinbeater
tinbeater's Avatar
Run a hot wire from the battery and see if they work??
If not you may have a broke wire or bad ground.
Old 12-12-2008, 04:50 PM   #10
even if they look good they may be bad, replace them anyways & try again.
Old 12-12-2008, 06:48 PM   #11
jeep93zj
jeep93zj's Avatar
i got it it was a bad ignition switch
89 xj 5" rustys
