Old 12-18-2008, 01:33 PM   #1
4.0L Motor Squeal
In the jeep, a high pitched squeel developed today. I isolated it to the engine (clutch in or in neutral, noise stops). The noise develops @ 2000rpm or above. It will do it sitting still. I'm thinking it is something on belt driven side. The idler puley can be spun by hand with the motor stopped.
Opinions? I don't just want to throw usless $$$ at it, but I don't want it to fall off when I go 'wheeling.
Old 12-18-2008, 01:56 PM   #2
Bear Chow
Bear Chow's Avatar
Have some one sit in the driver's seat and give it gas while you watch the pullies. My first bet would be loose belt, but than power steering pump or water pump. If you watch it when it begins to squeel you can actually see it stop turning even if it's for a moment. It doesn't cost any money to tighten up the belt first.
Check your power steering fluid level as well.
Old 12-18-2008, 02:28 PM   #3
jeep93zj
jeep93zj's Avatar
i had a throw out bearing make noise before when it was going bad
89 xj 5" rustys
93 zj 7" rockcrawler springs with rustys long arms
jeep93zj is offline   Reply With Quote
Old 12-18-2008, 02:33 PM   #4
you are rotating the idler pulley by hand with the belt still on it? Sounds like the belt tensioner is worn out.
Old 12-18-2008, 03:51 PM   #5
Sounds like a belt or it could be the sealed bearing in the idler pully , Mine went out a few months ago and screamed pretty loud.
But the whole clutch in thing worries me . My throw out bearing went out at the Fall crawl and there was no mistaking it it was loud !!!
Take a very long screw driver or pry bar and have someone give the Jeep some RPM's and use the screw driver / prybar like a stethascope ( SP? ) , put it on the alt. body , idler mount, water pump ..... put the handle in your ear. you will be able to locate the area the sound is coming from.
Old 12-18-2008, 05:18 PM   #6
eighty3bronco
anywhere but there
eighty3bronco's Avatar
I had the bearing fail on my AC compressor that squeeled. I had belt squeeling for 2 years when the air conditioner was on before the bearing decided to go out on it.
Old 12-19-2008, 07:03 PM   #7
Got it today during the warm spell
Idler pulley was just beginning to go. When it went in my previous truck, it was shifted to the side.
Thank goodness it was a $20 fix. I was afraid it was a power steering pump.
