Old 12-24-2008, 10:07 PM   #1
SixFtUnd
Danny Beach
SixFtUnd's Avatar
truck won't start
Bronco won't start
wouldn't start mon. morning and still won't start
I thought it might have been frozen gas line with that cold weather
but it's getting gas and getting spark
what to check next any ideas ?????
86 Ford Bronco
Old 12-24-2008, 10:40 PM   #2
Bear Chow
Bear Chow's Avatar
fuel, spark, air that's all it needs to atleast sputter. Clearify it won't start.
Old 12-24-2008, 11:18 PM   #3
Does it routinely fix itself?
Definitely need more data...
Old 12-24-2008, 11:19 PM   #4
timing
Old 12-25-2008, 10:11 AM   #5
SixFtUnd
Danny Beach
SixFtUnd's Avatar
more info humm
lets see
it cranks over but won't start I don't really know anything else to say
I'll try and check the timing I guess the chain could have jumped a tooth
86 Ford Bronco
Old 12-25-2008, 03:57 PM
Bear Chow
This message has been deleted by Bear Chow.
Old 12-25-2008, 04:47 PM   #6
JasonCJ7
Throttle Jockey
JasonCJ7's Avatar
Check the other electronics in the distributor. I.e. Cap, rotor, spark module.
Old 12-26-2008, 02:17 PM   #7
SixFtUnd
Danny Beach
SixFtUnd's Avatar
new plugs ,wires, cap, and button got it going also put a new Ignition modual but timing is off it was realy rough and would die I don't have a timing light but I ajusted the distibutor so it is runnung but kinda rought still
so would that mean the timing chain jumped a tooth?
86 Ford Bronco
Old 12-26-2008, 03:45 PM   #8
JasonCJ7
Throttle Jockey
JasonCJ7's Avatar
You may have fowled a plug if one of the other items was bad. Try pulling the plugs out and checking them. If they are bad the truck would run terrible.
Old 12-26-2008, 04:32 PM   #9
Vaccum leak, Fuel pressure, timing issue......................
Old 12-27-2008, 12:47 AM   #10
race4fn
what?where?whateva.....
race4fn's Avatar
I had a bronco that liked to kill ignition modules. Is the truck carbed or FI.
Put a timing light on it and see where your timing is at, I am not sure but it should be around 9 degrees with a stock cam. If it is way off try and get it close to that if you cant most likly its a stretched chain, you could have jumped a tooth but I have never seen that.
race4fn is offline   Reply With Quote
Old 12-27-2008, 06:02 PM   #11
SixFtUnd
Danny Beach
SixFtUnd's Avatar
carbed I have it running I just need a timing light to get it back in I guess
would like to have it running right for the 1st
86 Ford Bronco
