Old 02-15-2009, 09:51 PM   #1
trans. no shift at w.o.t.
I have recently purchased a 2000 dodge dakota r/t from a salvage yard (with a 5.9 360 v8 and 46re auto) and finally got it up and on the road. Problem is that at wide open throttle it revs out and bangs off the rev limiter and will not shift into 2nd until I get off the skinny pedal. If I drive it around at normal city driving throttle it shifts fine. While in 3rd gear if I hammer down it shifts to 1st and again will not shift to 2nd until I ease off the pedal. This is a huge problem because this truck will frequently see w.o.t. at the track. Any ideas? :confused: I am going to adjust the tv cable and see what happens.
Old 02-16-2009, 02:45 AM   #2
throttle position sensor.
mopar +4 fluids.
ask tinbeater he can get answers from
techs at his work...
Old 02-16-2009, 09:45 AM   #3
As you already mentioned, try adjusting the TV cable. That is definitely a sympton of a misadjusted TV cable. If I remember correctly, the 46RE still has bands that need adjusted for normal maintenance but is seems this rarely gets done.
Old 02-16-2009, 10:18 AM   #4
I bet the bands do need adjusted. I have never done this before and the shops I deal with do not like to do this probably due to job security!
Old 02-16-2009, 10:46 AM   #5
Switch to satellite and get rid of cable.
Old 02-16-2009, 10:49 AM   #6
seems obvious now
Old 02-16-2009, 10:59 AM   #7
Satellite is less reliable which is kind of like georges ford! (sorry George! :o )
Old 02-16-2009, 12:08 PM   #8
maddhatter
maddhatter's Avatar
Said the guy with the broke Dodge.
Old 02-16-2009, 12:11 PM   #9
maddhatter
maddhatter's Avatar
It sounds like a modulator but I don't even know if the newer Dodges still have them.
Old 02-16-2009, 03:57 PM   #10
My 700r4 in the camaro would do that while on the spray ( OF COURSE ONLY AT THE TRACK ), it ended up being the springs in the gov. were too week to over come the high line pressures at wot.
Old 02-16-2009, 04:21 PM   #11
This truck is a 408 forged stroker that once was on the bottle and maybe it was setup wrong or broken from a beating.
Old 02-16-2009, 05:07 PM   #12
cincygman
Only stupid people pay for cable (did I type that out loud?)
Sounds like TV cable, that was my first instinct before I read that you were going to try it............
I hear dead poeple............................................ ...................
Oh that was a good one Lisa
Romans 7-8
Old 02-16-2009, 08:21 PM   #13
tinbeater
tinbeater's Avatar
I can help. PM. sent.
Old 02-16-2009, 08:49 PM   #14
Awww, man.... I saw Tinbeater in the "replied last" and thought to myself "YES!, some real tech in this thread..." to find this...
Just kidding, and still interested in the Tech of this one...
Old 02-17-2009, 08:05 AM   #15
Adjusting the bands is pretty easy to do. The most time consuming part is pulling the pan, so at least it gives you a good excuse to change the fluid and filter.
It's been a couple years since I had to mess with one so can't remember the exact procedure but there is a good write up in the factory service manual.
