Old 03-28-2009, 03:15 PM   #1
fmlewis
The best damn Engineer!!!
Jeep CJ Transmission Mount Replacement
I am getting ready to replace the transmission mount in my CJ7. I noticed it has a steel bar between the mount and the transfer case.
Should I leave this steel bar on it or remove it and just put the new mount in its place?
FmLewis
Old 03-28-2009, 04:10 PM   #2
leave it in there... IMO
Often it is used to "tension" the poly/rubber of the mount... Horrible explanation, but I think you get what I'm saying...
I would need to see a pic to know the specifics in your case, but that's my guess.
Old 03-28-2009, 10:03 PM   #3
fmlewis
The new bushing from energy suspension came with a tension plate that the instructions say to install.
My Tcase is a Dana300 the bar I am talking about is a about 12 inches in length and 2.5inches in width. This bar has rolled edges almost like a c-channel but not as deep.
I am thinking about leaving it mounted there since it shouldn't really hurt anything, assuming the driveline angles are still acceptable.
Old 03-29-2009, 10:22 PM   #4
that bar helps with the twist of the tcase. On the far end of it, it should have a hole with a bushing it as well that mounts to the skid plate. The reason it is long is to counteract the rotational force of the tcase under load.
Keep it in there, and find you a bushing for the far end. The bushing rides on a custom bushing specific bolt... let me see if i can find some pics.
Old 03-29-2009, 10:30 PM   #5
Ohhhh, the torque arm thing... sorry, wasn't getting that.
Yeah, keep that.
Old 03-29-2009, 10:50 PM   #6
that's what it sounds like he describing to me.
Old 03-31-2009, 11:56 AM   #7
fmlewis
the torque arm is what I am talking about. sorry about that.
thanks for the info.
