Old 04-05-2009, 11:17 AM   #1
maddhatter
maddhatter's Avatar
Tranny / T-case help
I have a 85 CJ7 with a 258/T5/300.
OK, So if I had a 86 waggy with a 360 auto could I mount the motor and tranny to my Dana 300 case?
Will a auto mount to a Dana 300?
Old 04-07-2009, 10:01 AM   #2
kyrel69
yes but most likely will be a 727 tranny and your front drive shaft may not clear the tranny. It will depend on your front axle and how you clock your transfer case
Old 04-07-2009, 10:28 AM   #3
maddhatter
maddhatter's Avatar
So I have been told a AX15 will bolt up to my Dana 300.
I found a 92 YJ with a 4.0 / AX15 to use. Has anyone ever done this swap?
Old 04-07-2009, 10:41 AM   #4
kyrel69
yes a dana 300 will bolt up to a ax15 see link below for more infor
Old 04-07-2009, 10:43 AM   #5
kyrel69
here you go
http://www.novak-adapt.com/knowledge...on_gateway.htm
they have a lot of infor on different trannys
Old 04-07-2009, 11:32 AM   #6
maddhatter
maddhatter's Avatar
Thanks
I looks like the CJ is going to a have a 4.0 HO and a AX15 in it soon.
Making the EFI work should be fun but I have the whole YJ so I'm sure I will work it out.
