Old 04-10-2009, 05:32 PM   #1
bigbadxj
BIG DADDY
Heat under the Hood?
I know there has been a lot of arguing about cone filters and homemade inductions about how they just suck up hot air. But I was figuring since the intake and exhaust manifolds are right on top of each other the air is going to be super hot before combustion anyways right!?! Also everyone wants to know about headers, but isn't the stock exhaust manifolds almost like the aftermarket headers maybe just not as long but over all it has more of a header design than a lot of exhaust manafolds that or really badly designed. So My point is wouldn't taking off your stock manifold and sand blasting it and having it cerimic coated or rattle can coated and then wrapped be the best way to reduce heat in that area in turn making for more power and better running Jeep? Huh HUh what do you guys think?
bigbadxj is offline   Reply With Quote
Old 04-10-2009, 06:49 PM   #2
Try it and see what happens and let me know. May work but might not be all that noticeable. Time spent and money for heat wrap may not justify the project. Mud gets into the wrap also and makes a mess. Give it a tune-up and keep a hot thermostat in it for good mileage. Some headers are tuned and others have a coating to keep the heat in along with other performance differences. Good luck!
Old 04-10-2009, 07:29 PM   #3
bigbadxj
BIG DADDY
I found this link to a guy that did something to the effect of what I am talking about he spent a total of $70 bucks http://articles.jeepforum.com/Reduce...-_Exhaust_Wrap
Old 04-10-2009, 07:52 PM   #4
Maybe if you had the header off anyway.
That's a pretty big job, for the hope of slightly cooler air intake.
You probably be better off spacing the hood up like I did, or cutting a couple vents in it. That'd let a lot of heat out, and keep everything cooler.
Your call... good luck!
Old 04-10-2009, 09:38 PM   #5
Most guys in XJ's run hood vents , Lebaron vents are very popular also Grand Prix GTP's ( but the GTP's are hard to find and $$) . I would not suggest that you wrap your headers or manifold. There has been talk that wrapping them on an off road vehicle that sees mud and water will lead to rust problems. Find a set of Lebaron vents in the scrap yard and break out the die grinder .
Old 04-10-2009, 10:29 PM   #6
bigbadxj
BIG DADDY
Yea that is what it looks like I'll be doin thanks for the info guys
Old 04-11-2009, 01:52 AM   #7
The mud will act as a ceramic coating and insulate the header even more... atleast for the few months before they rust out from the moisture
Old 04-11-2009, 11:02 AM   #8
Meh, I've never seen a 4.0 header live long enough to rust.
They always crack first, when the wussy motor mounts wallow out...
Old 04-11-2009, 02:12 PM   #9
You guys can do what you want but,
for the record, my air intake is 2 inches or less away
from my header
can get pic's if you want them
been that way for years now
