Old 04-19-2009, 09:06 PM   #1
fmlewis
The best damn Engineer!!!
83 Jeep CJ Gas Tank Valves
I have a 21gallon Jeep CJ gas tank from my 83 CJ-7. There are two valves of some sort that are held in place by grommets and the sending unit.
I recently broke the fitting off of one of the valves. Does anyone know what these valves are called or where to buy them?
Thanks for the help.
Old 04-19-2009, 09:39 PM   #2
maddhatter
maddhatter's Avatar
Pressure release valves / Vapor recovery valves
Does it look like this?
Is your tank steel or plastic?
Old 04-19-2009, 10:01 PM   #3
maddhatter
maddhatter's Avatar
O if it will help you out you can have one. There from a 92 YJ.
Old 04-19-2009, 10:26 PM   #4
fmlewis
Yes, they look like that. My tank is plastic.
I actually have two of these tanks. One with the valves and sending unit and one without.
Old 04-20-2009, 12:57 PM   #5
fmlewis
Sent you a message
Old 05-10-2009, 12:59 PM   #6
maddhatter
maddhatter's Avatar
So did that valve I gave you work?
