Old 10-08-2009, 09:31 PM   #1
Talking YJ wiper motor stop
My YJ's wipers run fine but seem to stop in the middle of the windshield. It is rather annoying as they are directly in my line of sight. Thinking the motor has issues and the switch is inside. Linkage is good and tight. What do ya think? :confused:
Old 10-08-2009, 11:15 PM   #2
Does it matter if the wipers are on delay, low or high speed? Could be a timer fault
Old 10-09-2009, 12:22 AM   #3
jmb8813
01 jeep tj
jmb8813's Avatar
i thought if they did that it had to do with the switch
Old 10-09-2009, 06:46 AM   #4
Let me see tonight but I believe it does it on any setting.
Old 10-09-2009, 09:10 AM   #5
could the linksge be installed out of phase ? does it actually park or does it stop where you turn them off ?
Old 10-09-2009, 09:50 AM   #6
I need to look at them closer but I do know that when they turn off they are stopped in the middle of the wiper stroke which puts them directly vertical.
Old 10-09-2009, 10:18 AM   #7
take the linkage off at the motor and the rotate the wipers to your desired position and then reattach at the motor. sounds like someone installed out of phase
Old 10-09-2009, 11:29 AM   #8
jmb8813
01 jeep tj
jmb8813's Avatar
makes sense
Old 10-09-2009, 11:39 AM   #9
That would be too simple though. I wondered if that would make the wipers run too far in one direction but after looking at the linkage setup I think you have something. ;)
Old 10-09-2009, 01:44 PM   #10
thanks im not a mechanic i just play one on tv
Old 10-09-2009, 02:29 PM   #11
That explains alot...
Old 10-09-2009, 02:35 PM   #12
mike shelton
wiper motor park is out.. replace the motor. mike
Old 10-09-2009, 03:25 PM   #13
the motor just broke off the window and is dangling by the wires. Is this good? :o
Old 10-09-2009, 03:29 PM   #14
It think you found it
Old 10-12-2009, 09:14 PM   #15
BiggDaddy
BiggDaddy's Avatar
seats?
You could always just move your seats toward the center console. Then you could see better. It can't be as simple as the other stuff.
BiggDaddy
'82 CJ-7, 6" lift, stock axles
258, 35x15.50x15 TSL/SX
Rustoleum Gray
