Old 05-16-2007, 06:34 AM   #1
cincychris
cincychris's Avatar
hp 44 ?
i was wondering if anyone has ever used the dana 44 out of a 78 bronco with the cast radius mounts and radius arms on a xj. if so mabye someone could guide me in the right direction on how they did this. thanks
cincychris is offline   Reply With Quote
Old 05-16-2007, 07:58 AM   #2
I welded upper and lower connection points for a 4 link set up around the stock radius mounts. It worked out well!
Old 05-16-2007, 08:14 AM   #3
XJ667
Guest
Posts: n/a
I extended raduis arms for my old XJ. It worked great heres a pic of the arms and flex.
I took 2x2x1/4 square tubing and sleeved about 9 inches of boxed old arm. With a johnny joint on the end.
Old 05-16-2007, 08:56 AM   #4
JET455
JET455's Avatar
He did it the best way to use the axle end of the radius arm and use new tubes back to a better joint than the factory ford set up. And mount it all to a cross member. I did this to a guys jeep before and worked out really well.
Old 05-16-2007, 02:44 PM   #5
ive seen a build up of a tj using radius arms on JA... can't find the thread right now... but it worked out well... binds a little bit, but almost any suspension does at some point.
Old 05-16-2007, 06:26 PM   #6
cincychris
cincychris's Avatar
Thanks for the help guys. I made these brackets to bolt to the frame, to use the radius arms but i think i am going to have to make the arms a little diffrent to work out well.
Old 05-16-2007, 08:09 PM   #7
JET455
JET455's Avatar
Those look good but I would try to get them mounted in one crossmember set up.
When I did it I made the them mount to a whole trans/tcase skid plate that tide the uni-body together.
