Old 11-27-2009, 03:33 PM   #1
What is this worth?
What is this cage worth? I am thinking of buying it to use on my Sammy. It is 1 1/2" .120" DOM Tubing. Does it look safe? I was hoping someone could tell me as I am going to look at it tomorrow. Thanks Guys!
Old 11-27-2009, 04:06 PM   #2
any side shots?
Old 11-27-2009, 04:31 PM   #3
Here is one...
Old 11-27-2009, 09:20 PM   #4
Make sure all of the welds are good, there are NO dents in the tubing and the over all structure has not been tweaked.
Old 11-27-2009, 10:42 PM   #5
bends are sharp. not the best but are you entering the pro circuit with it? what type of tubing used? and wall thickness? I made my 1st truggy and brought it to haspin and ghost rolled it down a hill for a test before I ran it.
Old 11-28-2009, 07:49 AM   #6
1 1/2" x .120" DOM Tubing. Haspin is about the only place I go.
Old 11-29-2009, 05:32 PM   #7
Well I bought it today. Now I am going to spend all winter switching things over. Should I four link the front while I have it apart?
Old 11-29-2009, 05:50 PM   #8
um.....yes
Old 11-29-2009, 06:14 PM   #9
um.....yes
I figured that was a stupd question. Now If I only had the know how....:confused:
Old 11-29-2009, 07:07 PM   #10
kb9qdi
Storm Chaser
kb9qdi's Avatar
Good time to learn while its apart. I'm sure there plenty people around willing to lend a hand or help with questions. Thats what its all about.
Old 11-29-2009, 08:01 PM   #11
I agree. This club is full of some great people.
My first question: Where do I start with the four link?
Old 11-29-2009, 08:04 PM   #12
buckeyezuk
wheeler
buckeyezuk's Avatar
4 link
maybe decide on a wheelbase for axle placement.....
Old 11-29-2009, 08:12 PM   #13
I was thinking 100". Is thiss good? It is at 91"ish right now.
Old 11-30-2009, 01:25 PM   #14
cheapthrills49
VANILLA GORILLA
cheapthrills49's Avatar
now u need 2 decide what type of link set up u want.....i would suggest a 3-link for the front or double tri-angulated 4-link
Old 11-30-2009, 01:36 PM   #15
100'' is good for alot of different terrain and a light drivetrain. Axles, motor, steering, gearing etc...? :confused:
Old 11-30-2009, 05:11 PM   #16
i'd want a zuk to be around 96-99'' for crawling, and closer to 103'' if you plan on doing some hillclimbs too. that is going to depend on your tire sizes too. 103'' is what my plan for the zuk im' hopefully picking up this weekend will end up on 40'' red labels.
greg
Old 11-30-2009, 05:20 PM   #17
Axles = Dana 44's, Motor = 1.6 8v, Gearing = 5.13 diffs & 4.5:1 T-Case...
greg
I plan on doing a little of everything. Mostly trails like Haspin and The Badlands. I may shoot for 105"? This is all new to me.
As I stated above, this is all new to me. Why would you recommend a three link? Is it all worth it? It already has YJ springs up front?
Old 11-30-2009, 05:55 PM   #18
A three link is easier to design for the front because it takes up less space and the driveshaft can be hard to get a link in around. Also it will bind up less with there being less links.
Old 11-30-2009, 06:28 PM   #19
i like the idea of a 3 link for 2 reasons. 1) packaging is easier as mentioned above, it was a nightmare getting a dual triangulated 4 link to work on my jeep, the driveshaft was hard to miss with the upper link (resolved with a 2'' taller than wanted rideheight, and a bent upper link to clear). 2) you can still run mechanical steering with hydro assist, as the track bar keeps the axle located in line with the drag link through the axles arc, going 4 link will require full hydro. the main problems i have with the 3 link is the side to side swing of hte axle through the range of motion (again, from the trac bar), and the fact that if you break an upper, and you are running airshocks or coilovers, you just broke alot more than a heim or bushing, you also probably ripped the end off of your $hock.
you're going to need ot take tire size seriously into to consideration with your wheelbase too, you don't want ot be hung up on your belly everytime you come over somethinng.
Old 11-30-2009, 06:35 PM   #20
I currently am running 36" tires and do not want to go any bigger. I also already have full hydro steering.
Old 11-30-2009, 07:54 PM   #21
TheJeepGuy
I beleive this cage has a alot of potential,but inorder to be safe and strong,I would move and add some tubes that are more functional.REMEMBER,SAFETY FIRST.Good luck and have fun with your build.Also,sounds like the guys over on PIRATE4X4 are giving you some good advise also.
TheJeepGuy is offline   Reply With Quote
Old 11-30-2009, 08:03 PM   #22
Where would you recommend placing the tubes? Modify the pics in Paint please?
There are some great people on Pirate and there are as many, if not more douche bags that think just because you are new, you are garbage.
Old 12-01-2009, 12:32 AM   #23
TheJeepGuy
[QUOTE=biggin69;30674]Where would you recommend placing the tubes? Modify the pics in Paint please?
Sorry, don't do paint,but the tubes I was refering to is the main hoop which is directly behind your seats should have a X design for strength in the event of a rollover.Sometimes flops are very violent,also the long tubes running from the main hoop down to your rear shock mounting area could be moved out to the 90 degree bend of the main hoop for additional strength.No one likes to rollover,but if you do,you need all the protection you can get.
Old 12-01-2009, 04:57 PM   #24
[QUOTE=TheJeepGuy;30681]
Old 12-02-2009, 01:49 PM   #25
[QUOTE=TheJeepGuy;30681][QUOTE=biggin69;30674}
No one likes to rollover[/QUOTE]
SAYS WHO???? lol
