Old 12-02-2009, 07:34 PM   #1
Biggin's Sammy-ish Build
Here are a few pics of my build. I am taking everything (drivetrain) out of my Sammy and putting it all in the new chassis I picked up. Some pics are cell phone pics and are not the greatest. I will keep it updated as I go.
Specs: Dana 44's front and rear, 5.13 gears, 1.6l 8v, stock Sammy trans., Sammy transer case w/ 4:1 gears, 4 link rear, YJ's front, full hydro steering, all sitting on 36" tires.
ID:	1920   Click image for larger version
Old 12-02-2009, 09:10 PM   #2
Looks as tho you weren't to far off from a buggy to start with, what do you hope to gain with this new buggy chassis that you don't currently have?
Old 12-03-2009, 04:04 PM   #3
The old tubing was actually pipe which I did not like. I did not feel that it was safe. I do not have the capabilities to build a buggy from scratch. Safety is my main concern plus I enjoy working on this thing as much as I enjoy driving it.
Old 12-27-2009, 02:33 PM   #4
Update...
Got the motor in the new chassis this weekend. I had to order a new rear seal for the tranny so it and the t-case will go in this week.
Old 12-27-2009, 03:13 PM   #5
uglyoffroad
uglyoffroad's Avatar
Did you get that chassis from a guy in richmond ky? It looks just like one that was for sale on craigslist over there. If it is the same guy, I have bought a few parts off of him in the past.
UGLY OFFROAD
Old 12-27-2009, 03:23 PM   #6
I got it from a guy in Indy who got it from the guy in Richmond.
Old 03-17-2010, 06:31 PM   #7
Been awhile since I have had time to work on the rig bu I am starting to get back at it.
What material should I use for the four links? I want to try and keep it as light as possible.
Old 03-17-2010, 09:08 PM   #8
7075 aluminum or titanium!
Old 03-18-2010, 03:18 PM   #9
I am sure titanium is expensive...
Old 03-29-2010, 03:34 PM   #10
Alright, I now have tme to work on my rig. Getting ready to work on the suspension. I am thinking of ditching the 1.6 8v and Sammy trans for a Chevy 4.3 backed with an automatic tranny. What are your guys opinions on this and whattrans would be goog? I am thinking of keeping the Sammy t-case divorced so ???
Old 03-29-2010, 05:13 PM   #11
Find me if you are getting rid of the 1.6 8v. I am just down the street.
The T350 is simple cheap and reliable.
Old 03-29-2010, 06:28 PM   #12
I will keep you in mind. Is the T350 able to bolt to a 4.3?
Old 03-29-2010, 07:56 PM   #13
I beleive so. They are the SBC of V6's
http://www.novak-adapt.com/knowledge...l_block_v6.htm
Old 03-29-2010, 08:20 PM   #14
if i remember right the 4.3 and sbc are the same motor just 4.3 has 2 less cylinders so you can use any of the old style trans.... T350, T400, 700r4, etc...
Old 03-29-2010, 10:37 PM   #15
tinbeater
tinbeater's Avatar
The Samurai t-case wont last long behind a 4.3.
tinbeater
This message has been deleted by tinbeater. Reason: double post
Old 03-30-2010, 03:21 PM   #16
So, what would you recommend? A NP205 or 203? Or.....?
Old 03-30-2010, 04:04 PM   #17
x2...prob break it loadin it on the trailer...
Old 03-30-2010, 04:08 PM   #18
Old 05-11-2010, 08:01 PM   #19
Update...
Well it has been awhile since I have updated this thread but I have not had very much time to work on it. I finally got the rear end in. Thanks for the tubing Mike! The rear is pretty much done besides mounting the coils. I am hoping to have the front in by the end of the week.
Old 05-11-2010, 09:56 PM   #20
your gonna wanna tie that trus in somewhere else, or your going to twist it right off.
Old 05-12-2010, 06:19 PM   #21
What about something like this? Basically bend another identical tube, weld it to the axle at 90 deg. and tie the two together...
Name:	Axle Truss Idea 1.JPG
Old 05-12-2010, 06:29 PM   #22
Or this? I have a couple diff rings that I could use. Weld a tab on the truss tube and bolt it to the diff rig that has a tab on it?
Name:	Axle Truss Idea 2.JPG
Old 05-13-2010, 08:17 AM   #23
RD TRCTR
I vote for this as this should be indestrcutible.
Old 05-13-2010, 08:30 AM   #24
be careful about option 1. Remember to plan it so you can still service the diff.
Old 05-13-2010, 08:19 PM   #25
That is where I am at now. I do not know what to do. I am hoping to get it sitting on its own wieght this weekend and then I will work on the details....
