Old 01-20-2010, 03:53 PM   #1
cherokeefire
90 cherokee trans
Does anyone know if a 93 cherokee transmission will work with a 90 cherokee. Please help
cherokeefire is offline   Reply With Quote
Old 01-20-2010, 04:51 PM   #2
naxja.org
Very helpful and full of every bit of info you will ever need for a Xj.
Old 01-20-2010, 05:36 PM   #3
i'mma gonna say no... for some reason I think its 87-90 (renix stuff) only trannys with the electrical system.
Old 01-20-2010, 06:55 PM   #4
No I think i read about someone making it work but it took a lot. Go to naxja and do a search.
Old 01-21-2010, 02:03 AM   #5
You'd be better off with Ballou's 88.
(Is that falls through, I've got a high-mile '90 if you're hard up...)
Old 01-21-2010, 05:49 PM   #6
cherokeefire
difference between trannys
what is the difference between 40le trans and a 43 le trans and can you use one for the other
Old 01-21-2010, 05:50 PM   #7
cherokeefire
how many miles
Old 01-22-2010, 01:25 AM   #8
Originally Posted by cherokeefire View Post
how many miles
I think the Jeep's got nearly 200k, I'll check tomorrow or Saturday. I bought it that way, so I'll have to assume it's the original.
Old 01-22-2010, 09:46 PM   #9
If both output shaft(shaft before the T/C) splines are the same it should work.
