Old 01-29-2010, 11:24 PM   #1
thefuzz
thefuzz's Avatar
Exclamation trailers
how are you guys hauling your rigs on a car trailer if your 4x4 has a wide stance as far as wide tires on it?? how do you get them past or over the trailer fenders without tearing up the trailer fenders ??
Sgt Steve S.
thefuzz is offline   Reply With Quote
Old 01-29-2010, 11:30 PM   #2
JET455
JET455's Avatar
You build them stronger to drive over them.
Old 01-29-2010, 11:42 PM   #3
BIGRAM
Ready to Wheel!!!!!!!
BIGRAM's Avatar
I have built up wood blocks that set on the inside of the fenders.
Until it is built up that is.
My uncle has removable fenders on an aluminum trailer that is cool.
1994 Dodge Ram 5.9L SWB
Old 01-29-2010, 11:47 PM   #4
I measured my trailer before odering my wheels. I've got about 3/4" to spare.
Guys on full widths reinforce the fenders with angle iron, box tube, or two-by-fours.
Old 01-29-2010, 11:56 PM   #5
Trigger
I have a deckover trailer, so I don't have to worry about it.
Old 01-30-2010, 07:44 AM   #6
thefuzz
thefuzz's Avatar
could some of you posibly post a pic of how you did yours so i can get a idea of how to do mine? thanks !
Sgt Steve S.
Old 01-30-2010, 07:54 AM   #7
x2
Old 01-30-2010, 08:38 AM   #8
TomH
Gearhead
TomH's Avatar
x3
Old 01-30-2010, 12:05 PM   #9
my trailor fenders swivel up and remove if i need them too. then i drive over trailor tires and replace the fenders. pretty slick setup.
Old 01-30-2010, 01:42 PM   #10
Not mine, like I said mine just fits.
But one on NAXJA I happened to remember from just last week:
Not a great pic of the rails, but you get the idea.
S'not real complicated.
Old 01-30-2010, 05:43 PM   #11
Waffle's Avatar
Images: 10
My trailer is 83" between the fenders. Yota is 85" wide. Soon I'm going to mod the fenders so they flip out or remove completely. My only concern with leaving it "drive over" was if the rig was dead and I needed to winch it on. That would be a ***** with anything but a straight shot.
Old 01-30-2010, 06:04 PM   #12
It just occurred to me that my XJ is loaded and balanced just right when the rear tire just rubs the inside of the trailer fender.
On full widths, the tire would have to sit entirely behind the fender. I've accidentally loaded it like that before, and it left the tongue way too light. The trailer really wanted to wag.
Now I'm more careful.
Old 01-30-2010, 06:47 PM   #13
mine has regular fenders, with just a piece of angle iron inside for a support to the center of the fender. i drive directly over the tops of the original fenders, and have never had a problem. my old wheels and tires were more than halfway off the sides of the trailer (i was 96" outside of tire). i haven't loaded it with the new wheels and tires yet, so not sure about now.
Old 01-31-2010, 09:17 AM   #14
Deckovers bring the rig up really high and can be a bit more unstable in off camber situations. Gooseneck deckovers work great. Bumper pull equipment (bobcat) trailers usually come with strong enough fenders to drive over.
Old 01-31-2010, 11:53 AM   #15
[img]i was 96" outside of tire[/img]
jesus...
Old 01-31-2010, 11:59 AM   #16
donaldcon
donaldcon's Avatar
put the finders on quick disconnects so you cna remove thema nd drive over the tires then reinstall.
Old 01-31-2010, 06:07 PM   #17
cheapthrills49
VANILLA GORILLA
cheapthrills49's Avatar
i stood 2x10 on end like a floor truss, traced them out and cut them with a circular saw and the radius' with a saws-most. 4 carage bolts with lock washers and red loctite, been like that for years
trailer is 76.5" inside metal fenders and the 4walker is 88"
trailer is also 4 sale $800
Old 01-31-2010, 07:01 PM   #18
Trigger
My problem on my old trailer with fenders wasn't the fact that I couldn't drive over them, that was easy to fix. The issue I had was that my wheelbase prevented me from being able to load the trailer with enough tongue weight to pull effectively. The back tires were essentially sitting on the dovetail part of the trailer. In order to have enough tongue weight, I would have had to park the back wheels on top of the fenders and that wouldn't have worked. My only solution really was a deckover.
Old 01-31-2010, 07:49 PM   #19
kirbyiv
kirbyiv's Avatar
I am 84.5" sidewall to sidewall with a full width 60 front, 17x8 beadlocks with 4.5 BS and 14" wide tires. Trailer is 83.5 between fenders, I just let it squeeze between them, been working fine like that for 2 years. Just build drive-over fenders if you cant fit between them
Old 02-01-2010, 08:52 AM   #20
My trailer is about 83" between the fenders, and the front of my Blazer is about 87-88" wide. My temporary fix was to make wood ramps consisting of three 4x4's stacked on top of each other and then cut out to the same shape as the fenders and then fastened to the fenders with a couple of bolts. That temporary fix has been in place for 5-6 years now. I'm also lucky because the perfect loading puts my rear tires right up against these wood ramps, but as mentioned above if your rear tires need to be inbetween the fenders for proper loading you will have some issues.
The wood ramps I have now work great as you just pull it on and stop when the rear tires hit the ramps. But as also mentioned above there is some concern of getting the rig loaded or unloaded if something breaks. The worst case I have been in was no steering and the passenger side front axle shaft broke. Loading wasn't too bad once I had it lined up correctly but it's a little hairy not having any steering and the front tires sitting up on the ramp. Unloading was a pain and I had to have another vehicle help pull it off. Part of the problem was it was raining + steel deck = slick. With only one front wheel pulling and no steering the back wanted to slide over when trying to back over the ramps. I've never tried, but I'm guessing it would be rather difficult to load or unload in 2wd.
Old 02-01-2010, 09:22 AM   #21
cheapthrills49
VANILLA GORILLA
i broke a joint n my front drive shaft 2 weekends ago and loaded up n 2wd. driving over the frosty fenders and my steal ramps slick as hell, i had 2 bump it pretty hard and it made my butt hole pucker a bit. sucks bad i need a deck over!
