Old 04-05-2010, 09:34 AM   #1
fordman00
fordman00's Avatar
need help with samurai
I bought another samurai and I drove it from home all the way to college about 2.5 hours away. I went to stop and the clutch wasnt engaging. So I tried to fix it on the side of the road and couldnt figure it out. So I need help. Please.
Adam
Old 04-05-2010, 04:19 PM   #2
Broken cable???
Old 04-05-2010, 04:25 PM   #3
fordman00
fordman00's Avatar
no.i fixed it.the guy that put it ondid not put it on correct.
Old 04-08-2010, 08:22 PM   #4
fordman00
fordman00's Avatar
new issue
it doesnt want to go into gear that easy when i stop and start.sometimes it will go in easily others it needs a little encouragement.
Old 04-08-2010, 11:45 PM   #5
either adjustment or i have had dampner springs come loose and bind against the flywheel and cause the clutch to drag and act like its not disingaging. sounds like it needs to come apart and the answer will be obvious.
Old 04-09-2010, 12:49 AM   #6
fordman00
fordman00's Avatar
it worked just fine 10 min ago wen i went for a drive.
Old 04-09-2010, 04:33 AM   #7
sound like it might be a shifter sheet and getting stuck between gears....
Old 04-09-2010, 10:34 AM   #8
fordman00
fordman00's Avatar
went for a drive today, and was shifting fine.had no problems getting into first.
