Old 04-22-2010, 08:59 PM   #1
JB welding plastic tank reliably?
I have a 2" wide slit that is on the side of the tank that really leaks badly. Wondering if sanding and preping will work with some JB weld? What are your experiences? Thanks, Scott
Old 04-22-2010, 09:18 PM   #2
factory dodge?
what does it fit
Old 04-22-2010, 09:21 PM   #3
drain it and plastic weld it.
there are also epoxies that are made to do what you are doing, specifically for fuel tanks i believe.
Old 04-22-2010, 09:49 PM   #4
I used the fuel tank epoxy. It is resistant to gas and oils. It should last
Old 04-22-2010, 10:27 PM   #5
Waffle's Avatar
Images: 10
Harbor Freight has a plastic weld kit. Never used it though.
Old 04-23-2010, 06:44 AM   #6
It is on the Polaris RZRs. I had a log rip through the skid and tank. Went through 7 gallons in 5 minutes. Can gas tank epoxy be had at autozone or?
Old 04-23-2010, 06:50 AM   #7
blustroker
woods beater
blustroker's Avatar
yep you can get at autozone. The epoxy for plastic tanks works great. Used it on the tank on my atv about 2 yrs ago and its still holding fine.
Old 06-02-2010, 04:19 PM   #8
auto zone epoxy no good as it failed twice with major preping involved. who can weld plastic? polaris wants 570.00 for a fuel tank. I will weld up one from aluminum as a last resort if needed before I buy one from polaris.
Old 06-02-2010, 11:25 PM   #9
tinbeater
tinbeater's Avatar
I can and do repair plastic all the time. The first thing we need to do is find out what kind of materal it is. TPO. SMC. ect. ect. and then go from there. I can weld plastic and have both welding setups, air and airless but not all composite are repairable.
Old 06-02-2010, 11:37 PM   #10
i used jb weld on my jeeps old tank, zero prep, and it lasted over 5 years, and 175,000 miles when i got rid of the jeep. as far as i know, it's still holding strong (i sold teh jeep 3 years ago).
