Old 05-18-2010, 04:23 PM   #1
USMC4
Driveshaft Replacement
Hi everyone.I am new to offroading in a vehicle. I own a 1991 Samurai w/fuel injection with a SPOA Kit sitting on 33s etc and lost a drive shaft while driving on the street. I purchased this vehicle already trail ready or so I thought. I could not recover the driveshaft and need to replace it. Any suggestions?
USMC4 is offline   Reply With Quote
Old 05-18-2010, 05:21 PM   #2
8UP
If you don't have any luck here you might try Gotmudd website. Samurai guy's hang out there and stuff goes fairly cheap.
Old 05-18-2010, 10:12 PM
Old 05-18-2010, 10:26 PM   #3
USMC4
Thank you both for the suggestions. I will contact them both and post the results.
Old 05-19-2010, 07:00 AM   #4
hotrod
Diesel guy
hotrod's Avatar
B & T joint and shaft in milford. Talk to dave they made me one helluva shaft back in october.
2013 RZR S
Old 05-19-2010, 09:49 AM   #5
B & T joint and shaft in milford...
Ford quoted me $300 to pop a ujoint in the axleshaft of my F250.
B&T did it for $80.
That made me happy.
Old 05-19-2010, 06:12 PM   #6
B&T did it for $80.
That made me happy.
Why didnt you do it?
Old 05-19-2010, 07:08 PM   #7
X2 .... We both would have been happy and I would have done it for half
Old 05-20-2010, 01:01 AM   #8
Damn thing's as big around as a loaf of bread, there's no way it'd fit in my vise.
Besides, a cheap "brute force" joint was like $35, the Timkin they put in was $50.
It was just $25 labor, and then tax.
Old 05-20-2010, 07:32 AM   #9
hotrod
Diesel guy
hotrod's Avatar
ya b&t made me a rear shaft for my sammi, used a scout front shaft that i had laying around so it has beefier u-joints and they machined new flange yokes for me when they did it to fit my stock sammi t case and axle flanges, did it all in a day, picked it up from my work in the am and returned it to my work in the pm before i left for the day all for $165
2013 RZR S
Old 05-20-2010, 09:05 PM   #10
Two things... A 1410 u-joint (I'm assuming that's what it was) is twigs and toothpicks compared to the Rockwell junk... the endcap is as big around as a loaf of bread!!
And not to start another argument, but I've also always been told that pressing in a vise/press is less favorable to a BFH because it's easier to bend ears or get tweaked in the press....
Any thoughts?
Old 05-20-2010, 10:23 PM   #11
Any thoughts?
If that happens, get better sockets. I mean collets
I find the finesse of a press tends to reshape less things.
Old 05-20-2010, 10:42 PM   #12
hotrod
Diesel guy
hotrod's Avatar
when i use a BFH the needle bearings come out, never fails to piss me off and usually $41+ start flying :o i prefer a press/ vise much less of a headache for me.
2013 RZR S
Old 05-20-2010, 11:43 PM   #13
I do both: Squeeze it tight, then tap the side to get it to move.
Works for me.
Old 05-21-2010, 09:07 AM   #14
TheJeepGuy
u joint replacement
A couple of other items that help with the assembly is to lightly clean the holes with some emerypaper and spray....just enough to remove the rust and shine the holes up some.This really helps the cups slide in when using a vise or press.Most important start the cups straight with the holes and don't forget to spray everything down first.A little detail goes a long way.
TheJeepGuy is offline   Reply With Quote
Old 05-21-2010, 01:16 PM   #15
944drsk
1986 4runner
944drsk's Avatar
Does the anyone have a phone # for B&T, not in the Yellowpages.Looking for a front DS for the 4runnner. Thanks, Brett
MODS- A Bunch Of Stuff That Seems To Get Me In Alot Of Trouble...
944drsk is offline   Reply With Quote
Old 05-22-2010, 01:44 AM   #16
513-575-4200
Old 05-22-2010, 11:13 AM   #17
Not sure if they are open. Drove past the shop on 28 a few weeks ago and it looked like it was closed up.
Old 05-22-2010, 02:17 PM   #18
On 28? The place I went to was around the corner, on Branch Hill-Guinea Pike.
They just did my other shaft in the middle of April.
They are closed weekends, though.
Old 06-08-2010, 09:25 AM   #19
BTDRIVESHAFT
were open still just right around the corner at 6057 branch hill guinea pk
BTDRIVESHAFT is offline   Reply With Quote
Old 06-08-2010, 10:15 PM   #20
Been a while since I have been there. Did it used to be on 28?
Old 06-09-2010, 08:40 AM   #21
eighty3bronco
anywhere but there
eighty3bronco's Avatar
yes it was. right next to Branch Hill guinea pk across from the shell station
