Old 05-27-2010, 06:42 PM   #1
tom tom
tommy
tom tom's Avatar
wiring the back lights
Ok i got everything hooked up right so im told by someone who know a little about wiring buti still have no running turn or brake light and i know nothing about wiring lights can anyone help me point me inthe right derction its a yj 94
Old 05-27-2010, 08:48 PM   #2
SixFtUnd
Danny Beach
SixFtUnd's Avatar
do you want it done right or do you just want it to work ??? haha on my bronco I spliced into the headlight wires and ran from there to the back it had no tail lights when I got it
I'm sure you want more professional job but that will get you lights
86 Ford Bronco
Old 05-27-2010, 09:29 PM   #3
tom tom
tommy
tom tom's Avatar
that still wouldnt give me brake lights right
Old 05-27-2010, 10:29 PM   #4
check were they split in the rear for the two lights, mine had a short right there and was a little gremlin to find. other than that you have the lightis in and wired to oem specs? leds or factory lights?
Old 05-27-2010, 11:57 PM   #5
dan
gotta love middletucky
dan's Avatar
His lights are after market led and whoever put them in cut the factory harness and just wired them in that way they are not grounded to the body or frame its kinda a wiring nightmare
Old 05-28-2010, 07:43 AM   #6
Get a test light and run a new good ground wire. then turn on your running lights and connect the test light between the "for sure good ground" and the wires. The one that is hot (test light lights up) is your running lights, repeat prochedure for left turn signal & right turn signal, etc. Good luck!
Old 05-28-2010, 09:21 AM   #7
I agree, at this point that is yer best shot. Factory lights didnt have a ground they grounded threw the bolts on the back of the light ( at least on my cj and my old yj) its a 3 wire platform right?? brake,running, back ups?
On your Jeep the wire colors at the tail lamps should be as follows.
Reverse = white/black
turn/stop = white
park = light green/black
and it grounds through the housing.
Old 05-28-2010, 11:32 AM   #8
tom tom
tommy
tom tom's Avatar
turn/stop = white
Thanks for everyones input i will let you all know
Old 06-01-2010, 05:34 PM   #9
tom tom
tommy
tom tom's Avatar
back lights
it needed grounded to te bolt
Old 06-02-2010, 08:13 AM   #10
great!
