Old 07-20-2010, 09:22 AM   #1
brake lines
i have a 98 tj in the shop right now and all the metal brake lines and the fuel return are shot (rust) just wondering if anyone has any suggestions on where to get a prebent possibly stainless kit at. i have dealt with classic tube on old cars but havent called anywhere yet. suggestions?
thanks scott
Old 07-20-2010, 10:24 AM   #2
Classic tube carries jeep kits as well... in fact, 4wd carries that same kit from classic tube...
http://www.4wd.com/productdetails.aspx?partID=8247
ah, and an omix/ada kit here as well....
http://www.4wd.com/productdetails.aspx?partID=58749
Old 07-20-2010, 10:49 AM   #3
thank you. i was wondering about them just hadnt had the time to look. i have seen 3 98 tjs that the lines were junk on so i dont know if they(jeep)has learned anything from that
thanks again
Old 07-20-2010, 12:17 PM   #4
KennyTJ
KennyTJ's Avatar
The "green" hard brake line stuff at NAPA or any of the parts stores is hand bendable now days and is awsome stuff. You can get long enough sticks to handle any of the single line runs on a Jeep tub. We re-did the YJ and "moved" the lines to a better location than the factory run. Stuff also blows away the cost of the pre-bent lines as well.
Just my 2 cents worth.
Old 07-20-2010, 12:37 PM   #5
yes but factoring in the labor cost to do someone elses when you own a business is important....it would probably be cheaper to buy pre bent ones...just my .02
Old 07-20-2010, 01:12 PM   #6
agreed.
Old 07-20-2010, 02:36 PM   #7
yeah in a situation where im doing something for a build or myself i would be looking toward bending and flaring my own because for some dumb reason i actually like doing that but since this is stock and a customer replacement job i will be looking toward the prebent kit but thanks for the input.
thanks scott
Old 07-20-2010, 05:14 PM   #8
I used the pre bent brake lines from 4wdh when I put the new frame under my CJ 10 years ago.
Old 07-20-2010, 08:22 PM   #9
TomH
Gearhead
TomH's Avatar
Also check Inline Tube. They are in the same Michigan area as Classic and offer a lot of the same stuff (SS and Otherwise.) Both are old school good.
Old 07-20-2010, 09:27 PM   #10
began
began's Avatar
what a rust bucket....at least when it totally rusts away you can buy a gently used 6 inch long arm kit for you jeep
Old 07-20-2010, 11:57 PM   #11
The "green" hard brake line stuff at NAPA...
That's what I used to mate my 96 master with my 89 prop valve.
It did bend okay, but I had a hell of a time flaring it. I ended up having to scrape off all the green coating to get a grip on it...
Old 07-21-2010, 10:38 AM   #12
you seen it you know exactly what a nice peice of @#$% im working on. i called classic tube and they said i was third in line and they would call me back. that was yesterday so i would say they spend way to much time on the phone. i will try again
thanks scott
Old 07-21-2010, 09:22 PM   #13
thanks scott
They are horrible about calling back. I tried many times and left many messages and never heard back.
Old 07-23-2010, 01:46 PM   #14
called back to classic tube since it seems all the venders get there lines from them anyway and talked to tim who said that they had one guy retire and one on vacation and that he was the only one there at the moment so long story short the lines are ordered and i will let you know how they look and work
thanks scott
