Old 08-08-2010, 11:19 AM   #1
need help with 4.3 CPI motor
OK I give ! this thing has been the biggest pain in my arse I have ever had the pleasure of dealing with. I have the motor and trans in and all bolted down and it will not run worth a crap. I'm running on 3 cylinders. 1,5,2
Compression is good
new items :
Coil
dist.
cap
rotor
plugs
wires
fuel spider
I'm getting spark at all six plugs ?????
I have 2 marks on my balancer one is about 15 degrees off the other . I put it on top dead #1 on the first mark and it runs on 3 cyliders , put it on top dead # 1 on the second mark and it doesn't run at all .
Tried new computer with no change
I'm at a loss , is it a timing issue ???????
Anyone ?????
it's a 99 CPI vortec
Old 08-08-2010, 11:22 AM   #2
Was the distributor in it when you got it? Could it be off a tooth or two?
Old 08-08-2010, 11:40 AM   #3
no it was not in it ! or should I say It has been out. I think that might be the prob.???????
Old 08-08-2010, 02:11 PM   #4
Finally figured it out !!!!!!!!
thanks anyway
