Old 09-28-2010, 01:57 PM   #1
fmlewis
The best damn Engineer!!!
Alternator Upgrade
I have been doing some research on upgrading my alternator. I have an `83 4.2L. I recently acquired a Ford Taurus Radiator fan and plan to install that along with a higher output alternator. Do to the current from fan and room for future mods.
I currently have the stock 63amp version. Anyone know of a 120 - 165amp version that would be ideally a direct drop-in no fabrication work. If so, what year/model vehicle would it be found on? If not, to what extent of fabrication is needed.
What have you guys done who are running the taurus fan?
Old 09-28-2010, 02:50 PM   #2
kyrel69
well I do not have a 120 amp but do have a 105.
1990 jeep wrangler 2.5 motor with ac it is 105 amp. I just swap out the pully that comes on it with the V belt pully and have been useing it.
They are 90ish and come with a warranty at the local part stores
Old 09-28-2010, 09:45 PM   #3
Mike F
EFI AMC 360
Check out this site
http://www.extreme4wheelin.com/tech/...ators/tech.htm
All the delco alternators are listed. Notice the CS alternators have a different plug that you can get an adapter for.
Stay away from the CS 130s, they overheat and shut down and are open to dirt.
89 YJ EFI AMC 360, T18a, D20, built D44, 14 bolt, 38" Creepy Crawlers.
Mike F is offline   Reply With Quote
