Old 11-22-2010, 01:21 PM   #1
frankensteinxj
frankensteinxj's Avatar
kx125 not running
Ive got a kx125 and it wont run.
I cant get the damn thing to start unless if i pour gas directly through the air box into the carb. And when it starts up after doin that it runs full throttle until i hit the throttle and it bogs down. It is gettin fuel out of the petcock also so i know it isnt a problem with that. And i also put a new spark plug in it yeaterday.
Any ideas? Its drivin me insane.
BYAAH!!!
Old 11-22-2010, 04:36 PM   #2
lky13blazer
lky13blazer's Avatar
first thing I would do is take carb off n clean it...also check to make sure reeds aren't cracked.also sounds like you might be suckin air at the intake...
lky13blazer is offline   Reply With Quote
Old 11-22-2010, 09:03 PM   #3
cheapthrills49
VANILLA GORILLA
cheapthrills49's Avatar
buy a suzuki!
Old 11-22-2010, 09:22 PM   #4
Air leak , ether cracked intake boot..non-sealing reed valves or bad crank seal.
Whats the plug look like ?
Old 11-22-2010, 10:25 PM   #5
buy a suzuki!
do not do anything that drastic as it is probably just as simple as a thourough carb cleaning and rebuild.
Old 11-22-2010, 10:58 PM   #6
cheapthrills49
VANILLA GORILLA
drastic would be a handa!!!!
Old 11-23-2010, 09:04 AM   #7
krawlin85toy
krawlin85toy's Avatar
Images: 76
jets may be clogged from sitting and fuel dries crud up in them,done several carbs that have had this issue.
