Old 12-03-2010, 12:19 PM   #1
nickhuts
GRAB A SNATCH BLOCK!!
nickhuts's Avatar
need tires mounted
Who mounts 37s? I have called all the local places and nobody can. I am in liberty township thanks
Old 12-03-2010, 12:21 PM   #2
began
began's Avatar
try armstrong automotive...scot may be able to do it.
Old 12-03-2010, 12:31 PM   #3
pry bar and ether... that'll get it did
Old 12-03-2010, 01:09 PM   #4
fmlewis
The best damn Engineer!!!
Hilltop Performance mounted my 35". They are out in Harrison. Ask for Ethan or Andy.
Old 12-03-2010, 02:31 PM   #5
do it yourself.... not hard at all... the bigger the easier....
you can come by and i'll give ya a hand...
you got bare wheels ? or is there tires to be removed from the wheels?
Old 12-03-2010, 04:30 PM   #6
any shop could do it, just most wont.
i can do 37's on either my little atlas changer, or manually on the old school manual changer. big tire are usually easier to mount, just suck cause of the weight.
Old 12-03-2010, 08:45 PM   #7
kb9qdi
Storm Chaser
kb9qdi's Avatar
Hill Top in Harrison or I can at my Shop in Lawrenceburg. PM if interested.
Old 12-04-2010, 09:08 AM   #8
nickhuts
nickhuts's Avatar
Yea my buddy is takin off tires to put these on. Mid America tire does it in Middletown pretty cheap too.
Old 12-06-2010, 09:06 AM   #9
Don's Tire in Middletown can mount these. Some of the older tire changers can't fit anything larger than a 35" tire due to the arm being on the side.
Old 12-06-2010, 09:23 AM   #10
What do they charge Jason?
Old 12-07-2010, 10:38 AM   #11
no idea, don't have tires that big myself & change the rest of my tires myself. ;)
Old 12-07-2010, 06:34 PM   #12
nickhuts
nickhuts's Avatar
Bob sumerall off tylersville mounted the 37s no problem.
Has anyone ever heard of using bags of powder that burst open as you drive to ballance your tires??
$33 bucks a tire by the way
Old 12-07-2010, 07:31 PM   #13
Hotwheels
Hotwheels's Avatar
I can do them at my work if you want.
Old 12-08-2010, 04:47 PM   #14
HumminNBoatin
Like Nothing Else
HumminNBoatin's Avatar
I have the Equal Balancing bags in my truck. However $33 sounds steep I think I paid $100 at TD performance for them installed (dismount my 37's and remount my 37's.) They (Equal) are good but I would recommend you buy Dyna Beads instead. The Equal can get into the bead and cause slow leaking. Where as Dyna Beads do not.
What ever you choose they will make those tire very smooth on the road.
The Hummer Club Inc.
Director - Events Planning/Ambassador Program
Eric@TheHummerClubInc.com
www.thehummerclubinc.com
HumminNBoatin is offline   Reply With Quote
Old 12-08-2010, 05:22 PM   #15
began
began's Avatar
I used air soft pellets in mine...$12
Old 12-11-2010, 09:05 PM   #16
kb9qdi
Storm Chaser
kb9qdi's Avatar
My 35" KM2's are on 15x8 Steel Soft 8's dynamic balanced with no problems at all. I can run 70+ with my Aussie 4.88/8.8 set up with no vibes at all. I can see using pellets/Equal on larger tires or beadlocks otherwise its a waste to me. I balance **** up to 22-24.5's on Semi's/Motor Homes all day/everyday with no problems.
It really does depend on the tire/rig also. If your trying to get a set of Boggers balanced your wasting your time but a KM2 or MTZ no problem.
FYI....TD Peformance= Tire Discounters. I'm at the Lawrenceburg Store.
Old 12-12-2010, 07:13 PM   #17
nickhuts
nickhuts's Avatar
TD performance said they don't mount tires that big. We got em mounted though. Thanks
Old 12-12-2010, 07:37 PM   #18
fmlewis
I have found Myers Tire Supply in Reading sells Equal really cheap I think I paid $10 per bag for the my 35" Super Swampers. They balanced out great.
Old 12-12-2010, 08:59 PM   #19
kb9qdi
Storm Chaser
kb9qdi's Avatar
Thats messed up. They specialize in lifts,performance mods etc. Thats the store TD sends off the wall needs like that....lol I can't believe they blew you off, Amazing :(
Oh well.....FYI for anyone needing things of this nature we can do it at our store in Lawrenceburg also. Ask for Joe, If my TJ is in the lot I'm there.
