Old 12-15-2010, 07:07 AM   #1
NKYJEEPSTER
NKYJEEPSTER's Avatar
tire sidewall repairs
Anyone know a place around Cincy that can fix a hole in the sidewall of a tire? I got a pin head size hole in a tire looking to get it repaired.
Old 12-15-2010, 10:12 PM   #2
pitracer1
Jammin Jim
pitracer1's Avatar
Send a message via Yahoo to pitracer1
there is a place in milford, its on meijer drive. off hand cant think of the name but its on the left hand side.
pitracer1 is offline   Reply With Quote
Old 12-15-2010, 10:30 PM   #3
kb9qdi
Storm Chaser
kb9qdi's Avatar
Most shops won't repair a sidewall due to saftey but......some will, mainly independent shops. Options.....
Tube it, cheap but I personally wouldn't run on it everyday. Good for a spare in my eyes only or for a trail rig.
Try and pull thru patch plug....may/may not work.
Find a shop that vulcanizes sidewalls. Can be Pricey but usually works well,again I still wouldn't trust itfor a DD. I repair/sell tires for a living and have tried sidewall repairs for many fellow off roaders and most hold for awhile but usually fail over due time. If it's a tire your going to depend on every day I'd replace it and be done with it. Trail rig, I'd try the repair or use it for a spare. If it fails your not running 70 mph on the express way risking yours and everyone's life.
Some will say go for it no mater but I wouldn't on a DD. I see them fail everyday from sidewall flex and heat buildup. Usually when a tire runs low on air the sidewall heats up and the rubber gets soft/fails damaging the tire and or the sidewall making it unrepairable anyway.
Good Luck
Old 12-15-2010, 11:40 PM   #4
Pull through patch plug is what i have always had luck with on a sidewall.
as the above said, i would not DD a patched sidewall tire, must more prone to failing than a typical tread patch. use it as a spare if it is on a driver.
Old 12-16-2010, 01:31 AM   #5
http://www.cincyoffroad.com/forum/sh...ht=tire+repair
Old 12-16-2010, 09:11 AM   #6
jlynch
I have had 2 sidewalls repaired at Bob Sumerel tire in Dayton Ohio. They are used for offroad only but they are still holding air just fine. If you have a bias ply tire it will be easily fixable. One of my tires was a radial, they was able to fix it but it looks like ****. Price is reasonable also, hell of a lot cheaper than a new tire. Here is the address.
Bob Sumerel Tire
7711 Center Point 70 Blvd.
Dayton, OH 45424
Phone: (937) 235-0062
Fax: (937) 235-0064
Old 04-16-2011, 07:30 PM   #7
For those I've asked about this topic, I found the thread. Will call tomorrow to ask. I'll probably call the Milford one..though now I wonder if Dayton is closer to me. hmm
Best One Tire of Mid America Service manager Pete Waits 513-248-3900.
Old 04-17-2011, 10:14 AM   #8
KennyTJ
KennyTJ's Avatar
I had a nearly new IROC with a sidewall cut repaired in Milford at Best One, and it looks NEW! No problems, it is a bias tire, not sure if that makes a difference. They do the sidewall repair at the retread/recap shop.
I have had no problems, saved a $300 tire!
Old 04-17-2011, 01:05 PM   #9
tinbeater
tinbeater's Avatar
If you go to Milford ask for Steve blankenship
Old 04-18-2011, 11:29 AM   #10
Now to see how a 35 fits in the trunk of an x90
giggle
Old 04-18-2011, 01:41 PM   #11
giggle
Passenger seat.....The conversation would be as good as a mannequin
(sorry....Had to say it)
Old 04-19-2011, 10:28 AM   #12
I had a side wall patched on my Camry at Detroit tire in Xenia, its not far from Dayton. They would be closer than Center Point 70 if that is what I'm thinking is almost to New Carlisle.
Old 04-24-2011, 03:12 PM   #13
Got my tire back...Great people at Best One in Milford.
Old 04-24-2011, 05:22 PM   #14
Lisa, do you have any before and after pics of the repair? I have a nasty sidewall cut that I need repaired myslf. Nice junk in the trunk by the way!
Old 04-24-2011, 06:04 PM   #15
Didn't think to take any actually. I dealt with Ryan Bridley, Service/Fleet Manager, at 248-3900. Wish I'd have had time to do the tour of the repair facility..that'd been interesting.
Old 04-24-2011, 07:48 PM   #16
Thanks Lisa! I will give them a call tomorow.
Old 06-30-2011, 10:22 PM   #17
Maybe I missed it, but what did these shops charge you all for your repairs?
Old 07-01-2011, 07:50 AM   #18
vulcanizing (not sure on spelling) my sidewall was something like $40
and I still want to go tour it to see how the heck they do that
Old 07-01-2011, 08:51 AM   #19
If you go at the right time, you might even get supper out of it:p
Old 11-06-2012, 05:39 PM   #20
Time to dig up an old thread. Cut a side wall and took it to best one. They didn't really want anything to do with it but said they would try. We will see.
Old 11-06-2012, 05:45 PM   #21
Puckett at Shotgun does them.. a damn good job too
Old 11-06-2012, 05:46 PM   #22
Good luck. They told me the same thing on a tire I had. I told them it was an offroad only tire and if they could not fix, atleast they tried. They did not touch the tire.
LIKE IT OR LEAVE IT!!!
Old 11-06-2012, 06:00 PM   #23
Jonesy
Jonesy's Avatar
Got any contact info for Puckett? Slit one of the tractor tires on the yota. Tried patching it and didn't hold up.
JT Jones
83 Toyota - beater
87 Toyota Truggy
Old 11-06-2012, 06:37 PM   #24
I'm interested also of this doesn't work out
Old 11-06-2012, 08:45 PM   #25
Todds # at Shotgun Fab is 567-1117. In Verona right off 42 at the Boone/Gallatin Co. line.
