Old 02-01-2007, 11:10 PM   #1
dan
gotta love middletucky
dan's Avatar
35's
how bad would 35's be on a four bananger trying to decide on what tire size I want 35's but think the four banger would crap out or the ax5 would
Old 02-01-2007, 11:22 PM   #2
with stock gears, yes it will bring the suck.
Old 02-01-2007, 11:23 PM   #3
JET455
JET455's Avatar
you will need 4.88's to make it worth it.
Old 02-01-2007, 11:47 PM   #4
JET455
JET455's Avatar
By the way I have some 35's here I need to move did you ever get your blower/heat working?
Old 02-02-2007, 07:35 AM   #5
Bear Chow
Bear Chow's Avatar
That ax5 will go long before the 4cyl. If you do the gears you'll be fine, stock is miserable. And you have to worry about the rear axle if it's a 35C.
Old 02-02-2007, 09:29 PM   #6
dan
dan's Avatar
what kind of 35's, yea i got the heat working it was a twenty dollar switch
Old 02-02-2007, 09:48 PM   #7
with stock axles? (35 & 30)
Old 02-02-2007, 10:12 PM   #8
With stock axles and 4.88's I would find a light weight 33 that is not too wide. If you really want 35's try the super swamper tsl bias ply tires in a narrow width or the irocs.
Old 02-02-2007, 10:24 PM   #9
dan
dan's Avatar
if i go 35's going to get a set of 44s, actually i need to do that any way so i'm in the market if anybody has some
Old 02-02-2007, 10:40 PM   #10
I have a dana 44 with 4.56 ratio from a 1995 dodge ram. It comes with coil springs, steering linkage, steering box, steering pump, steering shaft, track bar, and 2 sets of extra inner axle shafts for the left and right side. 250.00
Old 02-03-2007, 06:22 AM   #11
dan
dan's Avatar
where are u located and my next day off isn't until tuesday would i be able to check them out then
Old 02-03-2007, 09:14 AM   #12
I may be able to do that. Let me see how this weekend goes.
Old 02-03-2007, 07:44 PM   #13
dan
dan's Avatar
just let me know
Old 02-03-2007, 11:54 PM   #14
dan
dan's Avatar
anybody know where to find some spring perches for a tj
Old 02-08-2007, 11:45 PM   #15
http://www.ruffstuffspecialties.com/...83a9b87168749c
there you go !!!
Old 02-09-2007, 07:47 AM   #16
dan
dan's Avatar
thanks sarge
Old 02-09-2007, 08:44 AM   #17
sarge, yer a butthole, how bout "contact carwash for spring perches for a TJ"
damn you.
Old 02-09-2007, 08:51 AM   #18
JET455
JET455's Avatar
damn you.
Ya! where's all your love Mike?
Old 02-09-2007, 08:58 AM   #19
Hey dan, carwash has top notch quality spring perches made of the finest materials known to man and JET455 can weld em in better than anyone. And it could be done this weekend. Maybe
Old 02-10-2007, 06:33 AM   #20
ooooppppps, I like your PG-13 Butt Hole comment !! it made me feel all warm and fuzzy
Hey Dan ,
This guy on our board ..... I think his name is CRANKWASHER or something like that sells parts from Ruff Stuff ..... you might want to give him a call
Old 02-10-2007, 07:40 AM   #21
dan
dan's Avatar
all right I'll get a hold of this crank washer guy first, hey carwash if you could pm me your number
Old 02-10-2007, 10:14 PM   #22
hehehehehehehehe
