Old 02-17-2011, 08:44 AM   #1
philjbergman
philjbergman's Avatar
nuetral safety switch 89 Jeep YJ AUTO
Where is the wiring for this? I'm coming into a buddies project swapping a 305 in a YJ and cannot find the switch. Is it in the steering column, under the dash by the doghouse? does it run up under the firewall to the engine bay? color? type of connector?
86 Sami buggy, Locked, CJ/RUF with missing links, Polaris Predator Carb, Yota powersteering and axles, 36's
philjbergman is offline   Reply With Quote
Old 02-17-2011, 12:12 PM   #2
krawlin85toy
krawlin85toy's Avatar
Images: 76
Are you using a gm trans? year? if jeep its on trans along with a gm trans.Its with shifter linkage on trans.
Old 02-17-2011, 01:09 PM   #3
philjbergman
Chevy trans in it now, but I'm just trying to bypass the switch to get the ignition wire to activate starter. The shift handle was on the steering column previously, which was swapped out with a non shifting steering column. (the chevy shifter is on top of the doghouse now)
Old 02-19-2011, 01:21 PM   #4
I dont know or remember exacly where it is but I had an electrical melt down at livingston several years ago, and when my Yj had the original engine. Below the battery tray there was on the firewall something that looked like a relay but had several wires going to it and the wires all had ring terminals. I think all we did was take the wires off and that allowed it to start in gear. I believe it also has several fusible links going to it. Hope that helps. I have no idea if it is anywhere near the correct info for you.
