03-07-2011, 07:12 AM | #1 |
Raising a Dodge?
I'm very new to all of this & I'm wondering if it is possible to just put springs in my 2005 Dakota club cab 4x4 to raise it up a couple inches rather than an entire suspension kit or a body lift kit?
03-07-2011, 10:13 AM | #2 |
You can put helper springs in the rear , but you are IFS in the front. You either have to buy a very expensive lift or straight axle it for any great amounts of lift. You can do a torsion bar crank and gain a little or re-key the torsion bars. I'm not a big fan of body lifts , but if you only want enough lift to go up a tire size or two you could put a 2" BL with a Torsion Bar Crank and an add-a-leaf in the rear and be good for some mild wheeling ..... IMHO
I have an 89 Dakota , standard cab , long bed 4x4 . it has air shocks on the rear and the torsion bars have been cranked . I can clear 31's but my ride is kinda harsh.... but it's a parts chaser/beater so I really don't care about ride quality. |
03-07-2011, 10:59 AM | #3 | |
03-07-2011, 01:05 PM | #4 |
I would think you would get 1.5" - 2" out of that set.
03-09-2011, 02:41 PM | #5 |
Are you sure the 2005 have torsion bar front suspension? I thought up to 2004 was torsion and 2005 went to struts. Anyways, I have a 2000 with torsion bars. I cranked mine up and added an add-a-leaf spring helpers on the rear and fit 31" tires just fine. If you have struts, I'm pretty sure someone makes a leveling kit which is just spacers that go on top of the struts.
03-09-2011, 11:57 PM | #6 | |
