Old 03-12-2011, 01:59 PM   #1
Little brown ants.
Every year we get little brown ants by the front door. I have tried to get rid of them but I cant seem to do it. Noticed today they are back. Any suggestions?
Old 03-12-2011, 04:08 PM   #2
My grandma used to dump boiling water on the ants.
Old 03-12-2011, 04:15 PM   #3
I had the same problem on our back door. I checked around the door and made sure there wan't any cracks. There was so I sealed them up and no more ants since. Find the entry point and seal it up.
Old 03-12-2011, 05:09 PM   #4
race10
race10's Avatar
Mine uses the same trick with cats.
Old 03-12-2011, 05:42 PM   #5
I poured oil and methanol around the areas they were coming from in my back yard and set it on fire. They came back! I then 1/4 sticked a few troublesome areas and they came back. Then I bought an ant eater and it ran away. Still had ants. So finally I went to our local hardware store and bought this ant and spider powder from ortho. I sprinkled it in the burned up and cratered areas and shazam! No ants in the house.
Old 03-12-2011, 05:54 PM   #6
I was goona sugest an anteater also but u beat me too it:). But those are hard to get now anyway cause the same parent company that owns interco also was the largest anteater supplier.
If ur ants are like mine, they only show up in early spring, then go away. Like ladybugs in the fall.
Old 03-13-2011, 08:12 PM   #7
The best thing I have found, is "Terro" liquid ant killer. Put some out on some pieces of foil, or buy it in the handy ready to bait format, and it works. At least it did for me, and my in-laws. There will be a period of increased activity when they find it, and then they dissapear.
Old 03-13-2011, 09:58 PM   #8
I have tried the stuff you spread around the house and I tried the spray that stays for 3 months. I guess those bait trap things are next. Thanks.
And no anteater. Next thing you know the kids will be riding it around the house.
Old 03-14-2011, 11:53 AM   #9
eighty3bronco
anywhere but there
eighty3bronco's Avatar
I think you should get one just for that purpose.
Old 03-15-2011, 12:33 PM   #10
Bear Chow
Bear Chow's Avatar
Boric Acid
