Old 03-14-2011, 01:52 PM   #1
CFD5
CFD5's Avatar
Help with Axle ID
Trying to figure out what axle is in a Geo Tracker I'm working on. Owner knows nothing about it or it's history. It is running toyota CV shafts, I picked up a junkyard tracker front diff but it is not the same. Very close but not it. Any toyota guys that can help me out. The drivers side Inner axleshaft is bent.
Thanks
Name:	geo front.jpg
Old 03-14-2011, 07:37 PM   #2
tinbeater
tinbeater's Avatar
Not all trackers are the same. What is the spline count on the one you have?
Old 03-14-2011, 07:54 PM   #3
CFD5
CFD5's Avatar
26 spline in the axle that is in it now. door tag reads 93 tracker.
the axle I got from a junkyard "93 tracker" is 21 spline.
Old 03-14-2011, 08:33 PM   #4
tinbeater
tinbeater's Avatar
Could it be one of Mikes???
http://www.zukiworld.com/month_02010...swithhagen.htm
Old 03-14-2011, 08:46 PM   #5
CFD5
CFD5's Avatar
Not sure? The housing is aluminum, you can see the mount broke from the housing and has been welded back. I thought it looked like this one, Rear toy 4cyl 8". It is running toy cv shafts and 3 to 5 bolt adapters between them.
Old 03-14-2011, 08:51 PM   #6
CFD5
CFD5's Avatar
Also, it did have the strap over it like he show's on the zukiworld site.
Old 03-15-2011, 08:20 AM   #7
donaldcon
donaldcon's Avatar
I think 96+ trackers, sidekicks vitaras ect have the 26 spline axles.
Some of the older ones with 16valves should too but you have to pull em to check em.
I'd search aroudn and grab a steel housing too. They are botl in and will do away with that aluminum stuff
Old 03-15-2011, 12:17 PM   #8
tinbeater
tinbeater's Avatar
Check out the Calmini Anvil, it may be one of those?????
Old 03-15-2011, 12:25 PM   #9
CFD5
CFD5's Avatar
Found a 96 shaft, I'll let you know when I get it so I can compare what I have. I'm starting to lean towards the 96+ with the toy cv shafts. Read somewhere online there was a guy years ago that sold an adapter kit for this. Thanks for the help, keep it coming.
Old 03-15-2011, 12:29 PM   #10
CFD5
CFD5's Avatar
I thought the Anvil was a steel housing? This one is alum.
