Old 03-19-2011, 03:13 AM   #1
Got me some new goodies for the yota axle build
well I found some hi steer arms which turned out to be part of a marlincrawler kit for my 85 yota axles.
now saving up for the locker and dirty 30's or boblongs....
also has anyone used the 25mm mc kingpin upgrade on there yota's? not sure if that should be in the works for my upgrade or not...
Old 03-19-2011, 08:11 AM   #2
8UP
I have an ARB air locker for a Toyota that I'll be taking to the local swap meet in a couple of weeks. It works perfect, has the usual marks on the case where the pinion scraped it, common on Toyota's, doesn't hurt anything. I replaced it when I went to the V-6 third member.
I'm going to price it at $400 at the swap meet, I'll take $350 for it if someone buy's it before then. Firm on the price, less than half the cost of a new one.
Old 03-19-2011, 09:49 AM
Old 03-23-2011, 04:58 PM   #3
hmm have to think on that one..
got me another goodie for the swap the other day from the junk yard..
89-95 4 runner rear d shaft
tcase end 42 degrees bend at the u-joint.
Old 03-23-2011, 04:59 PM   #4
What size tires? I wouldn't bother with the kingpin upgrade until you get to
39's. If you pass on the arb get an aussie locker with a solid pinion sleeve.
well i have to find some 16 rims for my 9.50x16 ag tires...
then pick up some 37 in tires and rims for rock crawling..
Old 03-30-2011, 06:11 PM   #5
parts so far
front 85 axle with 4.56 gears
rear 85 axles with 4.56 gears.
Marlin hi steer arms and drag link and pitman bars
4 cyc pig with locker
detroit locker for the front :lol:
Old 03-30-2011, 08:22 PM   #6
Who told you 4;56? I thought yotas were 4;30s and 4;88s???
Old 03-30-2011, 10:01 PM   #7
simpletoy
Count the teeth for us to check on those 4.56s
Old 03-31-2011, 12:04 AM   #8
dot on end of pinion.. yellow
Code:
Ratio Ring/Pinion Color Crawl:Ratio
3.42 ...42/12... Purple ...31:1
3.90 ...39/10... Red... ...36:1
4.10 ...41/10... Pink.. ...37:1
4.11 ...37/09... Orange ...37:1
4.30 ...43/10... Blue.. ...39:1
4.37 ...35/08... Green. ...40:1
4.56 ...41/09... Yellow ...41:1
4.88 ...39/08... White. ...44:1
5.29 ...37/07... None.. ...48:1
5.71 ...40/07... None.. ...51:1
they came out of 85 4cyc auto truck!
and yes i will count them for sure when the locker goes in it...
Old 04-09-2011, 01:27 AM   #9
Well I just finished up ording my new longfields and 5th bolt kit for the axles...budgeting this build to make them strong... flanges and some other little parts to still get before I start....
They will be in next week....FYI if you dont buy the new hub gear or flanges it will void the warrantyy on the axles... why you say... cus when the stock hub goes it normally will strip the splines on the axles...
Old 04-09-2011, 08:49 AM   #10
def buy drive flanges...much stronger in my opinion...if you run lockouts and bobby hub gears you HAVE to buy the arp hub studs or your lockout will blow off...literally....i seen one bout take a guys knee cap out once
Old 04-09-2011, 08:58 AM   #11
yeah going with the drive flanges...
Old 04-21-2011, 01:40 AM   #12
guess what is in the box????
Old 04-23-2011, 03:40 AM   #13
Well i purchase some new goodie tonight...
drive flanges
3" spacers
ARP studs
backing eleminators
fj-80 end
and some ther little things...
can not wait till they get here...
Soon I will get the woman to rebuild these axles for me...
Old 04-27-2011, 11:07 PM   #14
Well i did some progress on the axles, cut off the old steering arm crap and the shocks, not sure if i need the hi riser on the front axle yet or not so i left that...
more goodies to show up thursday or friday from TG... then the real fun begins....
Old 04-29-2011, 12:46 AM   #15
Trail-Gears parts came today so hope to get some good weather to work on the axles...:( darn rain...
