Old 07-26-2007, 05:54 PM   #1
nickhuts
GRAB A SNATCH BLOCK!!
nickhuts's Avatar
gear ratio
hey i know there is a way to divide the number of teath to find out the gear ratio..anyone know it off hand? i got to find out what rear gear is in my toy
Old 07-26-2007, 06:05 PM   #2
10 tooth pinion---41 tooth ring------41 divided by 10 = 4.10 that's your ratio, and so on.
Jeff
Old 07-27-2007, 01:03 AM   #3
eighty3bronco
anywhere but there
eighty3bronco's Avatar
Or you can turn the tires one revolution and count how many time that the pinion turns. IE: on turn of the tire and a little more then 4 tuns can equal ~ a 4.10 ratio. Hope this helps some to. That is if you do not wanto open the case up.
Old 07-27-2007, 08:50 AM   #4
if it's the stock axle, look for the tags as well.
Old 08-07-2007, 09:23 PM   #5
nickhuts
nickhuts's Avatar
alright i will check that out thanks guys
