Old 05-05-2011, 07:41 PM   #1
h3 hummer rims questions?
will h3 hummer rims fit on yota axles ? if you cut out the center hole?
:confused: trying to find some 16 rims 6 lug....
next question who can cut out a 4 in center hole in alum rim?
Old 05-05-2011, 10:04 PM   #2
you can look for some factory toyota rims... There are a couple different styles, from a newer Taco or 4runner... but i think the widest you might find is 8" wide...
Old 05-05-2011, 10:34 PM   #3
well i picked these up and found that the center hole is 3.85 in well I could just grind out the lip to make it 4 1/4" (108 mm) and it will fit over the hub. but the best new is I got 3" wheel spacers and it does not let the rim go back far enough to hit the hub so it is all good with grinding anything and I can still use the hummer center caps.
all is good!
