Old 05-27-2011, 11:09 PM   #1
nshefbuch
got some new meats
well i got new tires mounted and put on rocker guards too. next is some fender trimming and using TJ flares.
had to cut the run flats off so i can keep the dual beadlocks.
Old 05-28-2011, 01:15 AM   #2
kentuckytwostep
corsets make it tighter
kentuckytwostep's Avatar
Make sure you clean up all that mag dust before you do any steel grinding or welding... damn burnt my house done because I didn't. Luckly I had a hose close, which by the way makes that type of fire worse (but makes everything else not want to burn so it worked out).
my rig
Old 05-28-2011, 02:34 AM   #3
Looks good...There's a few of us heading to Big Rock today if your interested in testing them out.
Old 05-28-2011, 07:22 AM   #4
nshefbuch
Yes I cleaned up the mag dust. I emptied the garage to cut them and then swept the whole garage out. My fire extinguisher is hanging on the wall too.
I wish I could go to big rock but I don't have the anti wrap bar as I'm waiting still for the brackets to come in(3 weeks now carwash)! I also need to trim fenders and instal tj fender flares.
