Old 06-09-2011, 09:45 PM   #1
ran the truck dry
Apparently my fuel gauge is off about an 1/8th of a tank. Spent 6 hours today trying to get the damn thing restarted. Still wont fire. Whoever at ford thought it was a good idea to make the system so you can't bleed or prime it needs shot directly in the penis. Anyone with any great ideas on how to vet a ford 7.3 to fire after running it out of fuel? Its sitting next to thehouse right now on battery chargers waiting for me to throw a match at it.
Old 06-09-2011, 10:42 PM   #2
what year? powerstroke?
some of them you can open the fuel drain valve on the fuel filter houseing. as you'r cranking the truck over have someone open the valve for a few seconds until it starts. u may have to reapeat this a couple of times.
Old 06-09-2011, 11:06 PM   #3
Its a 99 power stroke. Batteries are up to 65 percent. Im thinking the lift pump is going to be my problem.
Old 06-10-2011, 06:31 AM   #4
How much fuel did you put back in it? My 12V ran out last winter and it took 6 gallons before it'd prime and start. The 97 powerjoke i had didn't need to be primed, it'd just start after some cranking so maybe just add more fuel??????
Old 06-10-2011, 08:26 AM   #5
kyrel69
you can also try filling the fuel filter up with fuel. I filled mine up when I changed the filter or it would take a while to start if I did not fill it up. Might have to do it a few time to get it to keep running
Old 06-10-2011, 08:27 AM   #6
Filled the filter first thing. Been checking it periodically ever since.
Old 06-10-2011, 08:26 AM   #7
I added $50 to it. It died pulling into the station. I coasted up to the pump.
