Old 06-14-2011, 11:23 AM   #1
fordman00
fordman00's Avatar
What chip to run on my superduty
I bought a 99 powerstroke with 165000 I'm lookin to buy a programmer soon to help with towing and fuel economy any suggestions?
Old 06-14-2011, 11:35 AM   #2
wheelin678
wheelin678's Avatar
ts/tony wildman tune
80hp of fury!!!!!!
wheelin678 is offline   Reply With Quote
Old 06-14-2011, 01:06 PM   #3
I run a ts performance 6 position on my 99 6 speed. I really like it. I run it on the 50 horse setting, sounds mean as **** turned up to the 140 horse setting, never driven on it though. Throttle respnse is sooooio much better with the chip. I've thought about sending it off and getting it reflashed, but I've honestly been so happy with the original settings that I haven't(plus I don't want to go back to stock, even for a short time) I got mine from extreme diesel performance. They bad the best deal when I got it, like $60 cheaper than everywhere else. Its like $50-$75 to have it reflashed everywhere I've seen.
Old 06-14-2011, 01:56 PM   #4
fordman00
fordman00's Avatar
If ya don't mind me asking how much did that run ya?
Old 06-14-2011, 01:58 PM   #5
my stroke had swamps custom tunes.. they are in Tennessee and pretty sure the will re-flash it for free till you are happy. thats how they were with mine at least
Old 06-14-2011, 02:28 PM   #6
I payed bt 2-250 for mine. Its been awhile. Swamps is where im going to send mine to. Heard nothing but good things about them.
Old 06-14-2011, 04:04 PM   #7
hotrod
Diesel guy
hotrod's Avatar
Bill at PHP can hook you up, or Cale. Tony Wildman has been having some family issues he past year or so, so he is a very hard man to get ahold of. It takes about 6 weeks to get TW tunes. My buddy has swamps tunes and he isnt very impressed, with stage 1s, d66, fuel system, adrenaline hpop and a built e4od my dmax on a 50 horse tune can wax him.
I just have generic TS tunes for now but soon to have Cale retune it. Here, this might help.
http://powerstrokearmy.com/forums/sh...ht=cale&page=2
2013 RZR S
Old 06-14-2011, 04:07 PM   #8
hotrod
Diesel guy
hotrod's Avatar
also GAUGES GAUGES GAUGES!!! boost, pyro and trans temp (if you have an auto)
these are a MUST so you dont melt pistons or boil trans fluid.
is yours an E99 or L99? there are a few differances between them like injectors, turbo, engine internals etc
2013 RZR S
Old 06-14-2011, 10:15 PM   #9
fordman00
fordman00's Avatar
How do you tell?
Old 06-15-2011, 01:22 AM   #10
hotrod
Diesel guy
hotrod's Avatar
Easiest way is the powerstroke badge, if it looks like the v8 Triton badge on the front fender its an e99. If its a black bar on the door its a l99.
What's your build date? Should be on the inside driver door jam on a sticker. After 12/10/98 is l99. You need to know this when ordering performance parts too.
Adding to the differences, e99s have a 15° hpop compaired to the 17° late, different pcm, also, fun fact the e99 cruise light doesn't come on when cruise is activated.
2013 RZR S
Old 06-15-2011, 07:20 AM   #11
fordman00
fordman00's Avatar
It's a later 99
Old 06-15-2011, 08:37 AM   #12
hotrod
Diesel guy
hotrod's Avatar
It's a later 99
thats good news imo
2013 RZR S
Old 06-15-2011, 08:55 AM   #13
fordman00
fordman00's Avatar
Great.I'm liking the ya chip found one on kt diesel 295 3
With 6 tunes.also what gauges should I run?boost vacuum,trans temp and egt?also since u seem to know a bit my ac isn't blowing out of my vents I checked pump seems fine?
Old 06-15-2011, 12:48 PM   #14
Check your vacuum pump ion the passenger fenderwell and make sure its working, if so, its a vacuum leak somewhere. Im chasing the same thing on mine right now. There's a thread at the top of the 7.3 forum right now on www.powerstrokenation.com about it I just started reading up on last night.
I just run boost and egt on mine bc its a manual. Id run tranny temp with an auto too.
Old 06-15-2011, 12:55 PM   #15
fordman00
fordman00's Avatar
Ok haha.that's me on PSN.
Old 06-15-2011, 02:05 PM   #16
Well ****, apparently im following yours on there then.
Old 06-15-2011, 02:21 PM   #17
fordman00
fordman00's Avatar
Haha.yup.my lines look fine they look sorta new i can hear my pump when I start it.rim just going to go buy some vaccum line and try that first after I check the blend door.I guess were s.o.l unless hot rod has advice later.lol
Old 06-15-2011, 07:21 PM   #18
fordman00
fordman00's Avatar
https://www.glowshiftdirect.com/cart.aspx
Are these gauges Alright?
Old 06-15-2011, 07:28 PM   #19
My ESOF hubs would leak vacuum so bad the air would go to defrost.
(Although now, I can't remember if that was all the time, or just when engaged...)
Old 06-15-2011, 07:39 PM   #20
fordman00
fordman00's Avatar
That's exactly what mine does.comes out the defrost when turned on
Old 06-15-2011, 10:08 PM
hotrod
This message has been deleted by hotrod.
Old 06-15-2011, 10:10 PM   #21
hotrod
Diesel guy
hotrod's Avatar
I'm not to sure on the vents, honestly never messed with it but ill see what I can find out. IMO steer clear of glowshift. The price is right but why trust a cheap gauge to a multi-thousand dollar rig? I run a quad pod in mine with air pressure (for air horns), boost, pyro, and eng oil temp with isspro EV series gauges. I got em from http://www.kensperformancesolutions.com/home.html good prices and his customer service is great. When I ordered online he called me about half hour later to conferm the order and make sure I got everything I needed. Shipping was very quick too.
2013 RZR S
Old 06-15-2011, 11:10 PM   #22
fordman00
fordman00's Avatar
Dang their the sane price four three gauges and a pillar.I'm assuming you have to buy wiring harness separate
Old 06-15-2011, 11:17 PM   #23
hotrod
Diesel guy
hotrod's Avatar
Red face
I believe you need to buy the Egt probe seperate but call Kenny, he is real easy to talk to and he makes sure you get everything you need.
2013 RZR S
Old 06-16-2011, 07:23 AM   #24
fordman00
fordman00's Avatar
Ok.sounds good might as well pay a little extra
Old 06-16-2011, 09:02 AM   #25
fordman00
fordman00's Avatar
Mckeddie check to see if your esof hubs are locking in properly and you 4wd is working if not vacuum leak
