Old 06-27-2011, 07:06 AM   #1
Roll over valves...
What should I use to keep all the fluids inside the parts they should be in when I roll over? I'm sick of getting covered in tranny fluid every time I go out.....:mad:
Old 06-27-2011, 07:42 AM   #2
Trigger
Learn how to wheel better?
Old 06-27-2011, 11:52 AM   #3
I figured that was coming
Old 06-27-2011, 11:57 AM   #4
im just glad someone else said it
Old 06-27-2011, 01:31 PM   #5
Get the inline ball valves within reach as u rout ur breathers. Then when u rollover remember to shut them. After u turn ign off. Keep all ur fluids in
Old 06-27-2011, 02:02 PM   #6
Was this a serious response?
I like getting covered in tranny fluid personally...
Old 06-27-2011, 02:11 PM   #7
That's cause you are a tranny !
Old 06-27-2011, 03:28 PM   #8
Yeah serious.... I mean have breather vents too... just when u roll, shut ball valves right away when u turn off ign, pane, and everything else. Just remember to open back up before driving.
What u never heard of that?:confused:
Old 06-27-2011, 04:16 PM   #9
i like getting covered in tranny fluid personally...
rotflmfao!
Old 06-27-2011, 05:43 PM   #10
redcj3a
redcj3a's Avatar
This is what I plan to replace my fuel tank's vent with. I interpret it as a vent as well as a rollover valve. Don't know what the trannys think of it. Hope the link works.
http://www.tanksinc.com/index.cfm?pt...prod&prd98.htm
Old 06-27-2011, 06:38 PM   #11
Yuck, tranny fluid. LOL
Old 06-27-2011, 08:30 PM   #12
How many ball valves would you need to do this method and where the hell would you put them all?
Old 06-27-2011, 08:34 PM   #13
I wanted some vacuum actuated valves like heater control valves to put in my PCV and breather vent lines, but I can't find any that are normally closed, meaning opened with vaccuum. I would love to flip a switch or just kill the engine when rolled over and shut off the path to the intake for the engine oil that seems to hydrolock mine or fill the breather full of oil. Anyone know of a normally closed vaccuum actuated valve for 3/8-5/8 lines? I would take several.
Old 06-27-2011, 08:48 PM   #14
Just get some tip-over valves with the ball in them... seems easy enough.
Old 06-27-2011, 08:52 PM   #15
http://www.spidertrax.com/Tip-Over-Valve
http://www.speedwaymotors.com/Fuel-T...alve,5848.html
And JAZ sells a bunch too, but they are more to be screwed into a fuel cell, not connected to a line.
Old 06-27-2011, 09:14 PM   #16
My rig rarely goes all the way over, although it does happen from time to time. Usually I am on my side, sucking oil out of the valve cover. I would like to be able to switch the PCV off and on at will.
Old 06-27-2011, 09:15 PM   #17
Route that PCV to a ball-valve, that's what yellowfaggot does.
Old 06-27-2011, 09:21 PM   #18
so YellowJ you have like 14 ball valves on yer dash???
Old 06-27-2011, 09:29 PM   #19
Yeah it looks like the city waterworks on his dash, he has 13 ball valves, 3 screw-type shut offs and a fire hydrant for flushing the system. He's waiting for his OSHA stamp of approval before he can enter the rig.
Old 06-27-2011, 09:31 PM   #20
lmfao.. tuff crowd
Old 06-27-2011, 09:39 PM   #21
i can sign off on mess of tipover valves if he needs!
Old 06-27-2011, 09:52 PM   #22
Y'all got me smilin. Wife looked over and asked what I laffin about.
I was goin more toward the transmission fluid problem he specifically mentioned. I been runnin a bv on tranny and tcase vent on my auto buggys for years. Got idea from randy torbett back when uroc was around maybe ten years ago or so. ( jwend that was an older rock crwl organization before werock got big....fyi )... lots of comp guys do it, I'm surprised it seems exotic to you. Most run bellows on axles, so not a issue there.
No wasent even ssugesting anything for motor... but redranger may be on to something.
Just throwin out remedies to his prob. Hope it helps!
Old 06-27-2011, 09:58 PM   #23
No wasent even ssugesting anything for motor... but white ranger may be on to something.
Sorry Im not super comp savy... If you actually wheeled in the woods instead of a cpu or garage you maybe a little less comp savy too... haha. We build em to beat um not talk about it.. lmao
Old 06-27-2011, 10:06 PM   #24
I just can't imagine trying to remember to shut off ball valves as I'm rolling over... let alone find them in such an instance. Anyway, if the comp guys do it, i guess it's legit...
Old 06-27-2011, 10:28 PM   #25
Lmfao! He must have like 3 different special shut off wrenches attached to small chains on the dash so dont loose them when he rolls
