Old 07-08-2011, 04:20 PM   #1
SixFtUnd
Danny Beach
SixFtUnd's Avatar
Gas Tank Leak
my gas tank has a small hole in the bottom here is a link so you can see what it looks like
http://www.autozone.com/autozone/par...127816_0_86880
I am thinking I would like to shrink the tank in half if I could remove the bottom half it would tuck up above my frame
I don't know if I can make the same fuel pump work or the fuel gage
Thought, Comments, Price to do the job if I bring you the tank or somewhere I could check into getting that done
86 Ford Bronco
Old 07-08-2011, 08:20 PM   #2
eighty3bronco
anywhere but there
eighty3bronco's Avatar
i have a plastic 33 gal tank to sell ya. i got it from jeffs bronco graveyard.
Old 07-08-2011, 08:36 PM   #3
SixFtUnd
Danny Beach
SixFtUnd's Avatar
thats probably the same size or bigger than what I have I'm hopping to go smaller
86 Ford Bronco
Old 07-08-2011, 09:03 PM   #4
donaldcon
donaldcon's Avatar
Some of the rangers had factory rear tanks that are 13 gallon, find one.
They are basically a BII tank half as tall. Get on car-parts.com and find a junkyard near you with one. 83-88 had them optional
Old 07-10-2011, 08:00 PM   #5
SixFtUnd
Danny Beach
SixFtUnd's Avatar
if I can't get this to work I will be going to U-Pull-N-Pay to look for that ranger tank
well I got the tank out cut it in half cut me a piece of steel to replace the bottom welded it on all was going good then I tested it to see if it would leak and sure enough it did I can't seem to get a good solid weld I have I think 4 or 5 spots that are leaking and I just can't seem to get them to stop
well any tips ????
86 Ford Bronco
Old 07-11-2011, 06:37 AM   #6
donaldcon
donaldcon's Avatar
yeah go to the yard and pull a ranger rear tank.
