Old 10-19-2011, 09:54 PM   #1
adjusting propane mixture
How do I go about adjusting the mixture on my Propane setup?I think its running rich. Im going through 20 lbs. In just 2hours of run time on a 22r with no real obstacles to speak of, just putting around main trail mostly. I want to try leaning it out. Its a gotpropane set up id that matters.
I know nothing about Propane.
Old 10-19-2011, 10:38 PM   #2
http://www.propane.tx.gov/commercial...mpcosystem.pdf
This link talks you through the main steps.
The main mixture valve should have markings that say R and L (Rich, Lean). Adjust as necessary.
Don't go to lean though. I was a bit lean one run and the exhaust got so hot that it turned a red cherry bomb half brown
Pretty much all of the gotpropane stuff is impco brand
