Old 11-22-2011, 07:47 PM   #1
Thumbs up Samurai T case shifter tool.
Well I first off will say was not my idea( thanks woodsrail).. Just had to make one..
I was wheeling Zuk Spook 11 and found that I lost my front wheel and where not spinning... tried to put the shifter in 4 low again and still nothing, try 4 hi and nothing.. so had to get pulled out and lost a window getting pulled around a tree..But now to the good stuff.
Some one said hey try the to pull the shifter out and see if it going into gear... well as we fumbled around to try and find something long enough to get down in the top of the t case to spin the little metal retainer ring.. I though it would be nice if there was a tool..to get this out!!!
Well woodrail just happened to have such a tool he made and worked soo good that I had to make one also...
so withe the shifter out I started to make one that would fit into the little slots and also be able to push down and turn all at the same time.
Here is what I came up with.
slotted so the shifter will slide into the middle and 2 little screws to go down into the side slots.
Here it is fitting into the slots.
I think i got about 15 bucks in it and about an hour making it.
Old 02-20-2014, 09:31 AM   #2
Disney
Disney's Avatar
Your pics are missing...
SKINNY PEDAL!!!SKINNY PEDAL!!!
Disney is offline   Reply With Quote
Old 02-20-2014, 01:41 PM   #3
i cant see **** either
Old 02-20-2014, 03:37 PM   #4
Looks good to me!
Old 02-20-2014, 07:50 PM   #5
You have to knock the dust off the 3 year old thread to see them.
Old 02-23-2014, 04:26 AM   #6
grrr looks the host location was deleted guess i need to reupload and link again for you all...
