Old 12-10-2011, 05:12 PM   #1
fordman00
fordman00's Avatar
Weird car start issue
My girlfriend has an 2000 Monte Carlo, it does this weird thing ever so often where it won't start, just plain won't so anything, no clicking no turbot over nothing, but if you keep trying to start it It wil eventually fire up no problems.has a newer battery. Any ideas?
Strokin' Away
Old 12-10-2011, 10:41 PM   #2
eighty3bronco
anywhere but there
eighty3bronco's Avatar
sounds like the ignition switch to me. when it happens if you wiggle the key around does it do anything?
Old 12-10-2011, 10:58 PM   #3
fordman00
fordman00's Avatar
Never done that I just keep turning ignition on and off until it fires, this is why I don't buy chevrolet.
Strokin' Away
Old 12-10-2011, 11:19 PM   #4
Jonesy
Jonesy's Avatar
Could be that the security system is loosing the resistance reading of the key. Once the key is in the ignition for a couple minutes it will reset and start. If that is the issue, it is a fairly common problem with GM Passlock system. Just went through this problem with an 03 Sunfire.
JT Jones
83 Toyota - beater
87 Toyota Truggy
Old 12-10-2011, 11:44 PM   #5
fordman00
fordman00's Avatar
Oh ok I see.
Strokin' Away
Old 12-15-2011, 10:39 AM   #6
Patrick45015
Have you checked both ends of the battery cables pos and neg starter connections.?People sometimes over look the simple stuff
Old 12-17-2011, 10:04 AM   #7
x2 on the security system. My father in-law had a Grand Prix and now an Ols Alero. Sometimes he needs to wait 45 min before his car will start. Garbage. Dealer says they cant do anything.
Old 12-17-2011, 11:53 AM   #8
My boss has a 2000 Astro and occasionally it will not start. It will start then die quickly. If you turn the key on, the security light blinks. After a while, it will start fine. If it doesn't do anything, then it could be the starter or the ignition switch.
Old 12-17-2011, 02:27 PM   #9
fordman00
fordman00's Avatar
Idk it's not worth puttin any money into, it Kbb for like 2000 maybe, I don't like all that security crap
Strokin' Away
Old 12-19-2011, 01:19 PM   #10
Just a shot in the dark but , Remove the positve battery cable from the battery and make sure the threaded stud is clean and all there . My wife's 02 Denali was giving me fits a few years ago not starting and slow cranking and the head lights would dim at idle. It ended up being the positive cable stud. it was almost completely gone. Put a new one in the rubber housing and cranked it down good and tight and have not have a problem since.
Old 12-19-2011, 03:08 PM   #11
muddinredneck513
muddinredneck513's Avatar
Want to sell it?
Old 12-19-2011, 06:37 PM   #12
fordman00
fordman00's Avatar
The Monte cArlo
Strokin' Away
Old 12-19-2011, 07:05 PM   #13
muddinredneck513
Ya
