Old 08-24-2007, 10:13 AM   #1
87yjinCincy
Jeep Noob
Send a message via AIM to 87yjinCincy Send a message via Yahoo to 87yjinCincy
motor question
Are the 4.2 AMC motors from the 79 CJ7 any good?
87yjinCincy is offline   Reply With Quote
Old 08-24-2007, 10:23 AM   #2
The straight 6 AMC 258 has a following of loyals... Some with the smaller 232 swap them in for an improvement in performance...
Same bolt pattern as an AMC V8 I believe...
Hope that helps...
Old 08-24-2007, 10:37 AM   #3
87yjinCincy
Jeep Noob
This may be a crazy question but is it a better motor than the straight 6 4.2 that's in my 87 YJ?
Old 08-24-2007, 11:32 AM   #4
I believe that the pre 75 4.2's are sought after. The 4.2 weighs 110lbs. more than the 4.0. Combine parts from both and make a stroker. To be as paticular on a year for the motor as you are would only be worth it if you were planning on making crazy amounts fo power from it.
