Old 02-06-2012, 08:02 PM   #1
NKYJEEPSTER
NKYJEEPSTER's Avatar
1986 Toyota 4Runner
Hate to sell, but some things have come up.
1986 Toyota 4runner
frame is solid. body is a little used.
heat works
still has all emissions stuff and working A/C compressor in it.
22RE
5 spd
Trans case has 1:1 high gear ratio and 4.7:1 low gear ratio T-G kit
trans/tcase have been tucked
twin sticked case
tcase has a brake on it, not working
front drive shaft is a square tube shaft
rear is a solid shaft
Front axle:
SAS'd with an 85 axle has 4.10 gears and locker
recently had knuckles serviced with TG kit
flip kit
high steer
hydro assist steering
diff covers armored
Rear axle:
86 with 4.10s and detroit locker
chevy 63" springs
36" TSL Swamper Bias with about 85% left on them
rock sliders all around it
has a cage over the back seat on the inside
front seats have 4 point harnesses and reg. belts
has a winch on it, but the negative cable going into the winch broke off
runs great goes great
have a good KY title in hand
I m sure I forgot something
asking $3500.
send me a text at 859-393-7760
Old 02-08-2012, 10:51 AM   #2
NKYJEEPSTER
still for sale, let s see what happens.
Old 02-29-2012, 11:15 PM   #3
NKYJEEPSTER
may trade for yota 4x4 that I can dd, 4 cyl. or maybe a 4x4 utility quad 400 or bigger.
Old 03-01-2012, 09:23 PM   #4
Trigger
Stupid question, but is it street legal?
Old 03-01-2012, 09:55 PM   #5
NKYJEEPSTER
I do not drive it on the street, but it has a clean title, headlights work(need new bulbs only high beams working now), brake lights work, not sure about the turn signals. It has been driven on the road, it would need some steering work and regear to daily drive it, so I always just trailered it. I plan to put 5.29s in it and fix steering. It needs either a new 4runner tie rod end for the pitman or upgrade to FJ80 pitman arm and tierod end. So yeah it could be driven on the road with a little work.
May trade for some guns and cash as well.
Old 06-20-2012, 10:13 AM   #6
NKYJEEPSTER
I fixed the one ton tie rod end and that issue is cleared up. Would be interested in trading for a decent 4runner with a 22re/22r or maybe a decent utility quad something 350 or bigger.
