Old 02-23-2012, 11:40 PM   #1
xplorer55
Guest
Posts: n/a
Exclamation gremlins in my blazer...
Iv got a 99 2dr blazer 4.3 vortec auto 4x4, she runs amazing. Doesn't spit sputter or bog down. But damnn she is sper hard to start. Once warmed up she'll start right up fine. But normally with a cold start I have to hit it with starting fuild. But once it starts runs flawless and will start back up. I put a new gas cap on, plugs,wires, cap, fuel filter..basically gave her a good tune up thinkin it was just old plugs or wires. Haven't tested fuel pump but wats weird is the pump doesn't prime until after I turn key off then I hear it kick on for 10 seconds or so. It kicks on when I try to start it. But when I just turn the key one notch it doesn't come on. I really don't think its a fuel pump issue due to how great it drives. 80mph down the high way with no issues... sooo why in the h+ll is my blazer soooo hard to get started? Fuel pressure reg? Temp sensor? Crank sensor? I'm stumped...what r y'all thinkin?
Old 02-23-2012, 11:42 PM   #2
xplorer55
Guest
Posts: n/a
Just seems like it doesn't hold pressure, or doesn't prime...
Old 02-24-2012, 06:32 AM   #3
cincygman
Have you tried turning the key on, without starting the engine, then off, three or four times to see if it primes the system? And really, starting fluid on a gas engine? Not good at all........
Romans 7-8
Old 02-24-2012, 07:15 AM   #4
race10
race10's Avatar
[QUOTE=cincygman;And really, starting fluid on a gas engine? Not good at all........[/QUOTE]
I've heard this a couple of times can anyone tell me what the big deal is?
Old 02-24-2012, 08:07 AM   #5
I knew that on a diesel starting fluid is bad.. real bad.. but gas too? Then what good is it?
Old 02-24-2012, 09:31 AM   #6
beading up tires
Old 02-24-2012, 09:58 AM   #7
I use ether for the first start of the year on my lawn mower, and snow blower if it doesn't start after the 3-4 pull. The snow blower is 30 plus and the mower is 28 years old.
We use ether when needed on diesel engines, always use in small amounts and don't heat the motor after it has been shot with ether. You can ether lock a motor.
Old 02-24-2012, 09:26 PM   #8
beading up tires
Yep,it's a bomb...
Please do not try this at home.(Standard Disclaimer)
