Old 02-25-2012, 09:49 PM   #1
BigRed
My jeep ate my wallet
BigRed's Avatar
XJ transfer case
I have a 92 Jeep Cherokee XJ Laredo edition. I'm trying to find out what type of Transfer Case I have. It appears that there are 4 types that went into XJs over the course of the XJ existence. Anyone know how to tell which one is which?
Plus. I need a replacement for the one I have. If you have one let me know.
-Dave
If my life's a joke, how much further is it to the punchline
BigRed is offline   Reply With Quote
Old 02-25-2012, 10:14 PM   #2
-Dave
Did you climb under it and see if the tag is still on it?
Old 02-25-2012, 10:19 PM   #3
i most likely do not have the shift patterns in the corect order.
there was the NP242. it should have teh following options 4wd full time-4wd hi part time-2wd-n-4wd low part time.
the np231 with 2wd-4wdhi-n-4wd low
these were the only 2 available in 1992. so if you have a 4wd full time option, you have the 242, if no full time 4wd option, you have the 231. the 231 is the more desirable of the two.
there are some minor differences within the cases themselves over the years, so you need to find one out of a similar year, (1991 and newer i believe) as the older ones had a different spline count on the input.
Old 02-25-2012, 11:03 PM   #4
Yep ,check the tag...
http://www.lunghd.com/Downloads_and_...tification.pdf
Theres a few(XJ'S) sitting at You-Pull
http://www.upullandpay.com/cincinnati/search-inventory
Old 02-25-2012, 11:28 PM   #5
BigRed
BigRed's Avatar
I must have the NP 242. I have the 4wd full time and part time option.
Thanks for your help. Now to find one.
Old 02-26-2012, 07:24 AM   #6
solar1
10
I have one that I pulled from a 92. Still connected to an AW4. I'll let it go cheap. Located inBerea south of Lexington.
Old 02-26-2012, 09:27 AM   #7
BigRed
BigRed's Avatar
Cool. How much? PM me.
Old 02-26-2012, 06:38 PM   #8
solar1
10
How about 125 and you get a spare AW4 tranny? I need it gone. Still connected to the 4.0,but we can separate it quickly if you are interested. They are sitting on a pallet in the back yard under a tarp.
Sent from Sputnik. Please send more Tang.
Old 02-27-2012, 05:08 PM   #9
BigRed
BigRed's Avatar
I think I see the problem. Not sure if the crack is the origin of the problem or a result of something else. The holes are easy to see but there is also a crack that went around.
I guess you could say Crack killed my jeep. I need to call Dr. Jeep.
ID:	5026   Click image for larger version
Old 02-27-2012, 06:44 PM   #10
solar1
10
Ouch. I just sent some pics for you.
Old 02-27-2012, 07:22 PM   #11
they are known for chain issues. did the exact same thing to the 242 in my cherokee. and the 249 in the grand, but it split all the way in half.
Old 02-28-2012, 09:08 AM   #12
Yep,that's a problem..Any luck finding a good one?
Old 02-28-2012, 10:43 AM   #13
BigRed
BigRed's Avatar
soler1 has one down in Brea, KY that looks goods. Kind of a far drive but if it's the best one then I will make the drive.
Do you think there might be one closer to Cincinnati?
I know that U pull n Pay has some Cherokees but with them you aren't sure of the condition of the parts.
