Old 02-28-2012, 01:27 PM   #1
coilover tech..
looking for spring rate info....
anyone here run coilovers and have info to share?
is spring rate determined just by the sprung weight of ur rig or by intended usage as well?( stiffer for faster ect)?
why do i see the springs all the way at the top of some c/o's and on others is spun down 6-7 inches?
how close or far away to keep spring rates....250 over 300 ...vs 150 over 300?
thanx in advance
Old 02-28-2012, 02:26 PM   #2
http://f-o-a.com/calculator.html
Better than I could explain.
Old 02-28-2012, 08:10 PM   #3
thanx....does this seem pretty accurate i guess?
im at 135 over 90 with main at 54... i hoped to be pretty light but these seem realllllly light...???
chassis at 500( just under)
guessing the rest....
sbc @ 400
tranny and atlas at 200
two tanks ..100
two fat guys....400
radiator /fan along w ten gallons ..130
two seats...60
exhaust, steering, two coolers and their fluids 150
half of suspension/ link weight...75
Old 02-28-2012, 08:14 PM   #4
above with d5 being 45"
and d6 being 48"
calculated with 18" travel at 60% droop. shocks at 10°...
just seems light but if im at 2015 sprung maybe its cool....i dunno:confused:
Old 02-28-2012, 09:47 PM   #5
is that tranny and t-case 200 each or together?
hopefully each, as i know the average auto tranny is close to 200 with a converter full of fluid, and i would put a t- case close to 100 lbs by itself, though i have never seen an atlas to know how much it would weigh.
and assuming you have an all iron SBC 400, you are about 200 lbs light on it as well.
just for reference, weights of different motors
http://www.team.net/sol/tech/engine.html
Old 02-28-2012, 10:23 PM   #6
yeah engine is all iron...i would not have thought it be 600 lbs though... thanx for the link. and i did allow extra for tranny cooler with fluid. any input is appreciated
Old 02-28-2012, 10:24 PM   #7
sbc (Dressed) @ 700
tranny and atlas at 350
two tanks ..120
two fat guys....500
two seats...60
Add it up and put in a bit of extra for straps, radio, cheezits....etc and call it 2700lb sprung weight
Plug it in and get 123/185. Problem is that you will need to pick a compromise of rates based on what is available. Based on this, I would think about 125/175. I am a novice though. I'm better at picking out regular coil spring rates.
Old 02-28-2012, 10:33 PM   #8
good:) im glad i itemized my componets for you guys to see. now i can see that i was pretty far off on my weights.
that must be why i can only pick up a sbc for 30 seconds...i just thought i was out of shape;)
seriously though ...those spring numbers do sound a lil closer to average
Old 02-28-2012, 10:39 PM   #9
you gonna run a winch that would need figured in to your weights as well?
what about front/rear distribution that would need accounted for as well.
Old 02-29-2012, 07:20 AM   #10
front winch is on axle. weight of rear winch has been accounted for. hoping for 50/50.... with weight changes you pointed out i better refigurr though.
Old 02-29-2012, 08:57 AM   #11
Your seats are 30 pounds each!?!? mine are about 10 maybe
Old 02-29-2012, 11:26 AM   #12
i think ill be buying some scales this weekend
Old 02-29-2012, 12:53 PM   #13
Todds' got corner scales if you want to get accurate #'s.
Old 02-29-2012, 01:37 PM   #14
hes a hard guy to get a hold of.... like trying to find dental floss at a willie nelson concert
Old 02-29-2012, 01:43 PM   #15
lmao...
Old 02-29-2012, 02:51 PM   #16
pm sent
Old 02-29-2012, 03:31 PM   #17
I have been told that with accurate corner weights they can get u pretty close to what u need
Old 02-29-2012, 10:29 PM   #18
Not right now, I think we have them.
