Old 03-19-2012, 12:21 PM   #1
line locks, ball valves
Ok so I put in the ball valve line locks got them all plumbed in bleed etc, when I step on the peddle to engage they ingage strong when I release the ball valve... They stay locked Wtf!? I am running a 67 Vette master and my axles are tons all with disc brakes.... Any clue on what's the dealy?
Old 03-19-2012, 12:38 PM   #2
I have traced it to the master cylinder, the valves work and so does the master in normal operating conditionsjust won't relase off presure after line is in locked.
Old 03-19-2012, 02:25 PM   #3
I have seen some instructions say that to release their valve, you should step on the pedal and then release the valve.
Old 03-19-2012, 06:21 PM   #4
That is odd. A manual valve should just release. All I got to do is flip the switch on mine and off it goes. You doing all 4 wheels? Maybe too much pressure coming back at once. Dunno...
Old 03-19-2012, 07:42 PM   #5
All I can say is Humpy is the man! He figured it out it was help pressure from the pedal
Old 03-19-2012, 08:48 PM   #6
Ain't no thang... Glad it's workin!!
Old 03-20-2012, 08:03 AM   #7
what does this mean?
Old 03-20-2012, 09:37 AM   #8
The piston wasn't returning all the way, held not help
Old 03-20-2012, 10:13 AM   #9
Oh, you swapped in the vette master but didnt modify your pushrod?
Old 03-20-2012, 10:32 AM   #10
I did mod it but it was a shade too long
Old 03-20-2012, 11:15 AM   #11
Tool Man
Tool Man's Avatar
please post a pic of this set up i would like to see it
Old 03-20-2012, 11:39 AM   #12
Will do,
Old 03-25-2012, 09:51 AM   #13
fmlewis
The best damn Engineer!!!
Will do,
I would liketo see the pic also. I'm just curious how you did it.
I am doing the same. I cut my push rod down to about 1/2 the original length. I took a barrel nut or all thread nut 3/18-16 drilled a small portion of it to allow it to slip on to the rod. Welded it in place and took some all thread crowned one end and cut so that the smallest length is 5-3/8". So I can adjust it out or cut it smaller if needed. I have heard you need about 5-5/8" in length from center to end. Mine can be adjusted to about 6" but i hope i don't need to go that far.
Also Speedway Motors sells an adjustable rod for $10 if you are not diy person.
Old 03-25-2012, 05:00 PM   #14
I bought an adjustable one from Napa years ago, it was marked as an adjustable clutch slave pushrod.
