Old 03-23-2012, 09:14 PM   #1
ruff idle on my 5.3
Got a Ruff idle on my 5.3, does anyone have a dignostic port for it and could help a brother out? It's in the jeep and I really don't want to trailer it to auto zone or take it to Cincy speed.
Old 03-23-2012, 09:41 PM   #2
TomH
Gearhead
TomH's Avatar
Are you talking about an OBD scanner?
If you're in the neighborhood (Anderson Twp.) stop by and you can plug it in.
Good luck.
Old 03-23-2012, 09:46 PM   #3
yeah its a obd scanner, prob is it is in my crawler and that makes logistics a issue
Old 03-24-2012, 11:12 AM   #4
Give Coby a call jason, i know he has a hand held.
Or buy yourself a cheap one, yer gonna need it in the future. Will suck to try to diagnose at camp without one.
Old 03-24-2012, 09:59 PM   #5
I had a buddy stop over today I am gona get one for sho, his was on his lap top and was pimp, you could adjust settings etc on it
Old 03-24-2012, 10:24 PM   #6
Did ya get it figured out? What was it?
Old 03-25-2012, 10:43 AM   #7
I had a few stored codes romoved those, re ran it and it reads its runin lean, gota figure out what's I need to.do to fix that
Old 03-25-2012, 10:57 AM   #8
How many miles are it? Does it do it all the time or is it worse when it is cold? The reason I ask is because my truck (1999, 5.3) started with a rough idle when it was cold, and continued to get worse over time and run rough when warm. Got lean codes, misfire bank 1 & 2 codes, yada, yada, yada. Finally narrowed it down to the intake gasket. Super easy to replace. Good luck tracking down the problem.
Old 03-25-2012, 11:00 AM   #9
X2 intake gaskets are a common problem on them.
Old 03-25-2012, 03:10 PM   #10
Yup intake gasket and replace #7 injector while it's apart... It collects the most ****
Old 03-25-2012, 09:51 PM   #11
kirbyiv
kirbyiv's Avatar
what type of fuel system are you running?
Old 03-26-2012, 11:18 AM   #12
Just FYI also , the LS motors will run like crap if the throttle body gets dirty , My 6.0 started running rough and stalling at stops. $3.99 bottle of TB cleaner and it runs great, I think I have cleaned everyones TB on my street now
Old 03-27-2012, 01:45 PM   #13
Walbro GSL392 Fuel Pump (External)
Fuel Filter/Regulator
20 Feet of 3/8" High Pressure Rubber Fuel Hose
Fuel Line Clamps
Adapters
thats my set up kirby,
http://www.ebay.com/itm/400212661347...84.m1423.l2648
