Old 06-14-2012, 11:52 AM   #1
XJ Parts
Parts off an 88 XJ
Front Dana 30 HP with 3.56 gears, knuckles drilled for 5/8" hiems and track bar setup for 5/8" bolt hiems. - $75
Homebrewed rock rails, they were originally welded to the uni-body. Either add feet to bolt the rails or weld it to the uni-body stiffeners. Made of 2" X 2" X 1/4" steel - $50
The start to an on-board welder - an alternator of a Crown Vic ( High amp 85ish?), mounting brackets to run a 5V belt off the power steering pump on an XJ, little electrical control box with 110 oultet to run brushed motor pieces of equipment while on the trail and some wire to make the connections for the true welding leads. -$75
ADDITIONAL PARTS
2 steering boxes one with stock pitman arm - $30 each
stock rear shaft from Aw4, 4x4 -$30
Stock alternator - $40
Intake manifold with all sensors and TB still on $40
I am getting out of the Jeep scene for a little bit, too many hobbies at the moment and this one would take me a bunch of time to get going. Make me an offer on everything and I can make a pretty good deal.
All of it for $150, minus the OBA and OBW setups. $250 with those.
