Old 06-27-2012, 07:27 PM   #1
Things I havebeen working before ZookiMelt 2012
Here are some pics of what I have been working on and getting done...Been a busy little guy. got the trailer lights hooked up but still have a little issue with hooking up the brakes. the wheels have 2 wires comeing out of each wheel.. no sure if it should be one ground and other blue wire on 7 way plug?:confused::confused:
https://www.facebook.com/media/set/?...1&l=eba02537e8
got the tin top back now at my buddy do alot of work on the 4 links and 3 links up front and putting on the shock mounts. he also worked on the my side and harley carb got it running good..
now just find a rear drive shaft ( cardigan one) and make a new front drive shaft and add some rear breaks... and exhaust..
SPlatt got the panty liner welded in and new tarp top made as i cut it down and added some grommets then some bungy balls to hold it on...
Also got the rear swing arm for tire carrier welded up and hard mounts to help hold it in place now stop all the raddling...
