Old 07-16-2012, 05:02 PM   #1
T-bird
T-bird's Avatar
Tire Groover
I am thinking about cutting the lugs on my LTB's because I don't think my tires contour to the rocks as well as they could under my light TJ. Does anyone have a tire groover or an easy way to cut the lugs?
Old 07-16-2012, 05:25 PM   #2
rilynsdad
rilynsdad's Avatar
I used a 1 1/4 wood chisel and a map-gas torch and heated up the chisel's tip to cut the small lugs on my bogger's it work pretty fast two tires in a hour not bad, it cut through like butter... I check out youtube first.
HOLD MY BEER!
Old 07-16-2012, 06:50 PM   #3
This ^^
Doing it this way is 10x faster than messing with a Ideal type groover..
Old 07-17-2012, 07:56 AM   #4
I'm sure the 1 1/4" wood chisel would be faster for cutting out the small lugs of a Bogger, but for cutting a 1/4 - 1/2" groove across a tread block the groover should be faster. Exact same concept with the exception you don't have to stop and heat up the blade with the torch. I cut a 1/2" groove through the middle of each tread block on my 39.5" TSL's in about 15-20 minutes per tire.
Old 07-17-2012, 09:07 AM   #5
cheapthrills49
VANILLA GORILLA
cheapthrills49's Avatar
Don't b a girl, use a chainsaw........faster than any grover out their. If you have a small battery powered or electric saw its one handed and effortless.
Old 07-17-2012, 10:33 AM   #6
T-bird
T-bird's Avatar
I was looking at something more like this
and not removing an entire lug.
Old 07-17-2012, 11:34 AM   #7
I did the center lugs of my previous Swampers (13/38-16s) like that with the smaller 1/4" blade. Twice as many cuts but not much more time since it cuts quicker.
Old 07-17-2012, 06:23 PM   #8
From your first post I was thinking you where wanting to remove whole lugs to let the tire flex better.
Would cutting a 1/4" wide 1/4" deep groove in each lug really improve flex that much.
Old 07-17-2012, 07:14 PM   #9
u&k metal works
u&k metal works's Avatar
He's right
Old 07-17-2012, 07:26 PM   #10
cheapthrills49
VANILLA GORILLA
O yeah, it adds 100 or so more pinch points per tire.....have you ever seen a late model tire? Thats the principle then air down
Old 07-17-2012, 07:29 PM   #11
cheapthrills49
VANILLA GORILLA
Just order the EL-CHEAPO from speedwaymotors.com
Old 07-19-2012, 08:57 AM   #12
T-bird
T-bird's Avatar
I have a good buddy that has one and is going to let me use it. I think it will really help in the rocks because right now my tires don't even start to bulge with 10 psi (no beadlocks). I think breaking up the lugs will help them flex and give them more edges to grab on.
Old 08-29-2012, 04:55 PM   #13
T-bird
T-bird's Avatar
I picked up the tire groover from my buddy and trying to figure out exactly what pattern to go with now. I will be gone this weekend so I should have them done sometime next week.
Old 08-29-2012, 06:03 PM   #14
chainsaw method FTW for grooving.
Old 08-31-2012, 12:50 PM   #15
kentuckytwostep
corsets make it tighter
kentuckytwostep's Avatar
I've got the center lugs on my XS's split in thirds with about 3/8" or 1/2" grooves and at 8psi they wrap around rocks like a hookers lips around a crack pipe :cheerleader:
my rig
Old 09-05-2012, 10:13 AM   #16
T-bird
T-bird's Avatar
I finished the first trail of tire cuts last night and I am pretty happy with them. I only did one cut per lug and could not belive how much more flexible the tires are. Before I had ran 10 PSI and the tire would hardly buldge at all when I hit a rock on the center of the tire. Now they will buldge out an inch with just the weight of the Jeep.
I am happy that I did not cut more than this for now because I still drive the Jeep to work on nice days and didn't want to ruin them. I will test the grip out next weekend at Slade and see if I want to cut anymore, but I wanted them to flex more and I am surprised how little of cutting it took to make sure a drastic differance.
